Vacuum Diagram
I have a 94 Civic with a b16 in it. I just put in a skunk 2 throttle body and intake manifold and I was wondering if anyone knew how to route the vacuum lines. I need to know how to run them from the charcoal canister and also where I should pull vacuum for the map sensor. Thanks in advance.
Smash
Smash
Thanks for the reply, but mine is from a 94 civic. The vacuum is a little different. I just put on the throttle body and intake manifold and now there's a serious vacuum problem. The idle won't hold steady. The fuel pressure is at 39 psi on idle. The thing is bogged down and it kinda sputters.
Dirtfall
16
Sep 20, 2005 04:00 AM
