Crx rear sway question
Old Apr 22, 2005 | 01:45 AM
Serdar's Avatar
Default Crx rear sway question
I have a 91 crx Si rear sway bar and rear LCAs will it be a good addition to my 91 crx Hf since it doesnt have a rear sway bar? and also what size is the bolts that attach the bar to the frame i dont have them???
Old Apr 22, 2005 | 02:47 AM
CRX_Control's Avatar
Default Re: Crx rear sway question (Serdar)
to attach it to the frame i think you use 2 14 mm on each side and make sure you have a nut on the other side of the bolt so that its threaded , to get nuts on the other side , I made a couple big holes in my trunk(some werent on the spot) but you only need to make two , one on each side .
-Eric
Old Apr 22, 2005 | 04:45 AM
fireant's Avatar
Default Re: Crx rear sway question (CRX_Control)
I hope the bar has the L-shaped brackets with it as well. They bolt on near the tow hooks, and the sway bar brackets hook to it. See number 14 below:
Arbiter
Nov 28, 2007 10:36 PM
Rostr02
May 20, 2004 10:03 PM
essex
Apr 14, 2003 10:54 AM
wronghand
May 4, 2002 08:42 PM
