H23 --> which H22 injectors for obdII H23
Old Apr 21, 2005 | 08:57 PM
PreLuDeSiR's Avatar
Default H23 --> which H22 injectors for obdII H23
i have a 96 prelude si with a h23 and its obdII. I want larger injectors and I know using h22 injectors is a cheap upgrade. I know obdI H22 injectors are recommended by honda-tech members for the h23 engine but which h22 injectors should I use for a obdII h23 and what else is neccesary for the installation besides the injectors and new rings? also, do i have to clean them or get them cleaned first? thanks
Old Apr 21, 2005 | 10:14 PM
SKDRCR's Avatar
Default Re: H23 --> which H22 injectors for obdII H23 (PreLuDeSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreLuDeSiR &raquo;</TD></TR><TR><TD CLASS="quote">i have a 96 prelude si with a h23 and its obdII. I want larger injectors and I know using h22 injectors is a cheap upgrade. I know obdI H22 injectors are recommended by honda-tech members for the h23 engine but which h22 injectors should I use for a obdII h23 and what else is neccesary for the installation besides the injectors and new rings? also, do i have to clean them or get them cleaned first? thanks</TD></TR></TABLE>
I'm guessing you have saturated injectors since your car is obd2.
Find some 5th gen h22 obd2 injectors if you want to upgrade.
edit:
According to str8rcn in the faq's, 96's are still peak and hold, so you could
probably use obd1 345cc injectors.
The only other thing that concerns me is you will still be running the p14 h23
fuel map, I guess you could turn up the flow with an aftermaket fpr.
Someone correct me if I'm wrong here.
Modified by SKDRCR at 1:26 AM 4/22/2005
Old Apr 26, 2005 | 10:15 AM
PreLuDeSiR's Avatar
Default Re: H23 --> which H22 injectors for obdII H23 (SKDRCR)
anybody else have any input?
mondiex
May 28, 2012 09:55 PM
yohan
Sep 27, 2004 08:33 PM
EFing8
Oct 28, 2002 10:04 AM
R6Boy69
Jun 9, 2001 03:03 PM
