F.S 90 accord 2.3vtec swap 5spd
ill be taking the motor tranny out and parting the car as just a shell if anyone here is interested in it tell me what you want and offer me a price
one of my sleeper projects that I have not finished yet
-other wise i will sell the car as a whole for the right price-
was hoping for a $1000 as is i know i can part it out for more
1990 accord lx 5spd with a 99 Acura cl 2.3L Vtec. OBD1 VEHICHLE
I got the motor from a 99 Acura cl automatic that only had 25K miles on it (so I know it wasn’t beat on). I matched it up with a act lightweight flywheel and act street extreme stage 2 clutch. And for gearing I used a 93 prelude Sir H23 transmission very close ratio to an h22 transmission without the first gear second gear tire spin. I had a p28 specially burned for this motor by v4lu3s .the chassis weights 2700#
engine is a 2.3L vtec sohc
tranny is SiR H23 5spd
clutch is ACT stage 2 street
flywheel is ACT extreme lightweight
obx rail
aem pullys
ceramic header
blocked egr
p28 reporgrammed for f23 for extra
What the car needs. Injectors and fuel rail. , I have the stock rail if you want it the fuel line will have to be custom made to use it. Also needs a passenger side axle or you can use the stock one but it will needs the clamp. Car is perfect for a sleeper reason I got it. The interior is in almost mint condition.
Car does run sometimes. It needs a new engine harness. I have seen them on ebay for $35 but I have never jumped on the auction. So basically for 150 you can get this car going and have a very fast sleeper or fix the rust and have a nice show car. Blue book is 2800 in good condition and considering the engine mileage you can probley get 3500. Car is located in north olmsted ohio and will need to be trailered or fix it here i dont care.
obx rail
aem pullys
ceramic header
blocked egr
Guest
Posts: n/a
it starts sometimes bc of engine harness? how do u know its that problem? reason i asked bc i've been having starting problem also. it runs a code reading catalyst effiency, u know what it means? the car does start sometimes, it takes a while before it turns over. bump by the way
ive changed everything in the car main relay, dizzy, ignition, plugs,fpr,lines,maps,tps, iacv, and i changed computers. Traced it down to the dist. sensor the one that pinpoints what cylinder its on. and it started up when i jumped a19 or a21 tellow green wire. thats how i know its a harness. but i got video of this badboy running
car is for sale locally for 1500 i figured i throw to a fellow hando guy that i know will take care of her at the 1000 price
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOMBCRU »</TD></TR><TR><TD CLASS="quote">Car is located in north olmsted ohio</TD></TR></TABLE>
Where is that exactly? I'm in Beaver County PA, about 5 minutes from the PA/OH line, are you remotely close to that?
cleveland about a hour out, the cars listed locally for 1500 inthe paper starting tommarrow i gave yall a week at this price, i expect it to sale real fast
