Flat black with a LITTLe bit of shine?
I was wondering what paint is used on the flat blacks..
Skunk 2 Rsx color
its flat black but still has a lil bit of shine to it.
whats the code for the paint and who makes it
.jpg)
I want this color code!!!!
Modified by JDMlyfestyle at 9:18 PM 4/21/2005
Skunk 2 Rsx color
.jpg)
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MilanoFury »</TD></TR><TR><TD CLASS="quote">it looks like it is satin black.</TD></TR></TABLE>
Hit the nail on the head.
Its called Satin Black.
You could either use flat black with some clearcoat OR go with the satin black with clearcoat if needed.
Satin is a little more glossy than the flat but you may need to either wetsand or clearcoat it to get the appropriate shine to it.
its probably a special mix, PPG paint I would assume. there wouldnt really be a code for a custom color, at least not available to the public. Just use Satin Black
Are you looking to use a paint gun or rattle can?
Rattle can you should be able to find a satin black in most if not all car parts stores and hardware stores.
If you are looking to spray it using a paint gun I would talk a car painting shop and ask them to mix you a satin black; shouldn't be too hard.
nah man the clear is shot on after the paint is laid down.....the type of paint job used on the rsx is a black color with a satin finish....I did this on my friends car a while back on the roof and trunk....something we did to hide the oxidation till real paint job could be applied....there is no color code for it....just go to your local auto paint store and tell them you want a Satin finish black color when it is shot it will look just like that....it is a single stage paint so no clear should be applied to it....hope this helps ya
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicEKCP »</TD></TR><TR><TD CLASS="quote">nah man the clear is shot on after the paint is laid down.....the type of paint job used on the rsx is a black color with a satin finish....I did this on my friends car a while back on the roof and trunk....something we did to hide the oxidation till real paint job could be applied....there is no color code for it....just go to your local auto paint store and tell them you want a Satin finish black color when it is shot it will look just like that....it is a single stage paint so no clear should be applied to it....hope this helps ya</TD></TR></TABLE>
Thank you sir!!!
Ill go check today
Thank you sir!!!
Ill go check today
W O T
Paint and Body
16
Nov 26, 2007 09:55 PM
deckster333
Feb 8, 2007 12:47 PM
