Had a sohc head magnafluxed but ...
Old Apr 21, 2005 | 12:38 PM
bazookatooth's Avatar
Default Had a sohc head magnafluxed but ... Please Help
I purchased a used sohc head on ebay. I had the thing tested, milled, and cleaned. The guy says he has to take it apart to do so, which is fine but Ive never taken a head apart before let alone put one back together. I want to do this head swap tomarrow but im gonna get it without the cam and camgear on it I think. Is this a big deal? I know ill have to do timing when I do the head swap but this will be my first time so I dont wanna **** anything up. Where can I get the info I need? Thanks.
Old Apr 21, 2005 | 12:41 PM
SOHC4life 96's Avatar
Default Re: Had a sohc head magnafluxed but ... (bazookatooth)
As long as you get the cam on the new head set to TDC (top dead center) and the engine set the same, you won't have to mess with the time much or at all. Make sure you use assembly lube if the came is new. Use it liberally on the cam and all the points where it contacts the head.
Old Apr 21, 2005 | 12:46 PM
Default Re: Had a sohc head magnafluxed but ... (SOHC4life 96)
How do I set it to TDC?
Old Apr 21, 2005 | 12:48 PM
I'm not sure, as I haven't come across having to do it yet. But do a search and check the FAQ thread on the top, I'm sure you will come across it.
eruiz85
11
Oct 8, 2013 09:49 AM
mudpuppy4life
Jun 9, 2011 07:19 PM
dark_samurai73
Dec 20, 2008 03:09 PM
cookiemonster0000
Oct 12, 2005 06:10 PM
beanbandit
Mar 28, 2005 10:23 AM
