88 hatch died
Old Apr 21, 2005 | 12:18 PM
89 crix si's Avatar
Default 88 hatch died
i got a 88 hatch with d15b7 and complete si interior and engine harness. what happened was i was driving then stopped and the car just died. after that it would turn over but just wont start. what could be wrong?
Old Apr 21, 2005 | 12:25 PM
FalkenSiR's Avatar
Default Re: 88 hatch died (89 crix si)
yeah.... ignitor.
most likely...
Old Apr 21, 2005 | 12:28 PM
EFz6er's Avatar
Default Re: 88 hatch died (fast88std)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std &raquo;</TD></TR><TR><TD CLASS="quote">yeah.... ignitor.
most likely...</TD></TR></TABLE>
are there any signs that your ignitor is about to go? My tach just recently began to be all jumpy and I read that the ignitor has something to do with that. Anything like that happen to your hatch?
Old Apr 21, 2005 | 01:01 PM
ironchef25's Avatar
Default Re: 88 hatch died (EFz6er)
well mine was like that. b16 crx. i was driving and all of the sudden the motor died. pulled over and check disb. looked at the ignition coil and it was burnt up.the little metal thing on my cap that connects to the ignition coil was melted. so i had to replace the ignition coil plus caps. now all better.
Old Apr 21, 2005 | 01:27 PM
jonleeone's Avatar
it happened to me once... but it was while i was driving. what happened to me was my ECU fuse burnt up, but then there's alot of other **** that could be wrong like maybe ur dizzy is just bad or you're not getting any spark from wires... or all ur spark plugs are burnt... maybe it's time to change them.
Old Apr 21, 2005 | 01:44 PM
89 crix si's Avatar
Default Re: 88 hatch died (jonL_EF)
it has brand new plugs, and i tried switching the dizzy and it still wont start
Old Apr 21, 2005 | 03:15 PM
BuLLDoGG's Avatar
i had the same thing with my 88 hatch;the screw came out of the rotor;and wasnt spinning with the cam
HONDA_CIVIC_HATCH_Boy
Feb 4, 2006 01:57 PM
theemaddhatterr
14
Jun 6, 2004 03:33 PM
EL Vap133
15
Oct 24, 2003 08:27 AM
