h22vtec exhaust on a h23 will it work?
Old Apr 21, 2005 | 11:28 AM
fonioflip's Avatar
Default h22vtec exhaust on a h23 will it work?
i have a h23... but i wanna use an rs-r ex mag exhaust. on the listings, it says they only make it for the h22... so... i'm wondering... is the outlet size on the exhaust manifold from a stock h22 the same as an outlet on a stock h23?... and would it matter if i had headers (DC sports 4-2-1 2-piece) or not... or will i be able to use headers from a h22a also?...
i want an rs-r cause it's quiet... but i don't know if it'll fit on my car.
any help is appreciated. thanks
Old Apr 21, 2005 | 11:42 AM
mesh's Avatar
Default Re: h22vtec exhaust on a h23 will it work? (fonioflip)
yeah, I would like to know this as well :D
Old Apr 21, 2005 | 12:21 PM
syntax.'s Avatar
I installed the rs*r cat-back for the h22 vtec on my 92 prelude si (h23) without any problems at all. I am using a cheap ebay header and downpipe connected to the stock cat. As long as you are going to use the stock cat or a replacement that has the same flange bolt pattern, you should be golden.
Old Apr 21, 2005 | 02:38 PM
92SleeperH23's Avatar
Default Re: h22vtec exhaust on a h23 will it work? (syntax420)
nice to know this, i've been wanting to know for a while whether the RS*R would fit on my Si
23series
Sep 24, 2007 11:44 PM
user 720822-1
Dec 31, 2006 07:36 PM
pinecone
Jul 26, 2006 07:56 AM
hprelude93
Nov 9, 2005 01:30 AM
mxer518
Apr 5, 2005 07:10 AM
