went to the track last night
Old Apr 21, 2005 | 09:31 AM
kch22t's Avatar
Default went to the track last night
I was shooting for 13 pass but
r/t .359
60' 2.549
330 6.511
1/8
mph
1000 12.150
1/4 14.292
mph 106.25
my car 4gen h22 with t3/4 turbo 10psi treet tires can't get traction till end of 4th gear
better luck next time
Old Apr 21, 2005 | 09:45 AM
monalisa overdrive's Avatar
Default Re: went to the track last night (kch22t)
whoa there, that 60 ft is insane.... you need to get some sticky *** rubber on that car immediately. what were you launching at? what's your suspension setup?
btw nice reaction time
Old Apr 21, 2005 | 10:41 AM
kch22t's Avatar
Default Re: went to the track last night (monalisa overdrive)
I know street tires suck , well i got stock shock+shitty maxspeed coilover. And i launched at 2k rpm above that car just sit still and burn out tires
Old Apr 21, 2005 | 10:43 AM
IHateJDM's Avatar
yeah, that 60' kicked your ***. I can only imagine your traction problems though. Get some drag radials and traction bars, and you'll be well into the 13's.
Old Apr 21, 2005 | 04:57 PM
h22PreludeSi's Avatar
just out of curiosity...
are you running stock valve train?
Old Apr 21, 2005 | 05:00 PM
Under_Pressure's Avatar
Default Re: (h22PreludeSi)
What tranny are you using?
Old Apr 21, 2005 | 05:05 PM
SKDRCR's Avatar
Default Re: (92h22alude)
That's a pretty good trap speed.
13's should be easily attainable with better tires.
I see you are from KC
I'd like to check your car out sometime.
I'm hoping to reach high 13's all motor by the end of the season
Old Apr 21, 2005 | 06:12 PM
kch22t's Avatar
i'm runing stock h22 tranny
upgrade valve train with stock cams, fully built bottom end
car built by MINH's motorsport
Old Apr 21, 2005 | 06:21 PM
SKDRCR's Avatar
Default Re: (kch22t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kch22t &raquo;</TD></TR><TR><TD CLASS="quote">i'm runing stock h22 tranny
car built by MINH's motorsport</TD></TR></TABLE>
Are you a customer or do you work there?
What ems are you using?
Old Apr 21, 2005 | 06:44 PM
kch22t's Avatar
Default Re: (SKDRCR)
i'm a customer , i'm using aem ems tuned by bill
Old Apr 21, 2005 | 06:46 PM
kch22t's Avatar
my car is a dark green prelude with white left door
Captn. Save A Hoe
Oct 27, 2003 12:50 AM
Jockobo
Nov 8, 2002 05:57 AM
CRXGhettoGuru
Apr 8, 2002 02:03 PM
HX_Guy
Oct 11, 2001 07:25 AM
