can I use ZEX flywheel with my 91 civic Si tranny???
Old Apr 21, 2005 | 08:45 AM
phoQ's Avatar
Default can I use ZEX flywheel with my 91 civic Si tranny???
i was looking for application on their site but all they said was do you want 6 blot or 8 bolt. Will one of them work with my 91 SI tranny?
Old Apr 21, 2005 | 09:41 AM
Mach69's Avatar
Default Re: can I use ZEX flywheel with my 91 civic Si tranny??? (phoQ)
Well the '91 Si transmission had 6 bolts hold the flywheel to the crankshaft. However, I would call zex and ask them the size of the clutch that is to be used for the flywheel. It should be ~8 3/8" or 212mm. That is the size of the clutch the '91 Si uses.
Old Apr 21, 2005 | 11:47 AM
phoQ's Avatar
thanks
Reason01
13
May 1, 2010 09:38 AM
whokid_911
Oct 6, 2009 07:03 PM
Xemu
Oct 6, 2006 10:10 PM
wfocrx
Sep 24, 2006 10:46 PM
CvccMugen
15
Jan 15, 2006 04:27 PM
