All You Smart HONDA GUYS PLEASE HELP!!!!!!!!!!!!!!!!!!
I ordered a B&M Fuel Regulator for my Civic Zc Dohc and it is leaking i even put the rubber gasket on and got a little bit bigger gasket and it still leaks. Do you think that the fuel pump is pushing out to much pressure and making it leak. Please Help ME
No the stock fuel pump should not make the regulator leak. Did you follow the directions correctly when modifying the stock regulator?
http://www.c-speedracing.com/h...r.php
Follow that, and it will not leak. Get the right rubber gasket in there.
"http://www.c-speedracing.com/h...r.php
Follow that, and it will not leak. Get the right rubber gasket in there."
thats a good writeup
