200whp All motor h22 need drag radial info...
JDM type S in 93 EG hatch, wanna hit the track next week but want some drag radials to see if I can make a difference. Going on GSR fat 5s what would be the best tire size and brand setup for my power and bodystyle..
Thanks in advance..
Thanks in advance..
Something that has an overall height of about 22". My buddies EG with H22 used some once, but I can not remember the size. IM me and I will give you his address to ask him.
sounds like you wanna run nhra street stock class, if so i would suggest getting a set of bfg drag radials. go to http://tirerack.com and look under bfg tires, they will list all the sizes available!
http://www.tirerack.com/tires/...adial this is a better link
BFG drag radials.205-50-15 if you're slammed. all motor they shouldn't spin.
if you're lowered an inch or less (boosted or forced) 225-50-15..also depends on what offset your rim is.
i'm gonna be running 225-50-15 bfg drags on my H juiced setup.
gdrum
Oct 31, 2003 06:56 AM
