Stock fuel presure on an ITR
Old Apr 21, 2005 | 06:57 AM
USDM EG's Avatar
Default Stock fuel presure on an ITR
I was just wondering what the stock fuel pressure is set at on a Integra Type R Motor.... thank you...
right now mine is set at 39 psi at idle.... i think thats a lil too high...
Old Apr 21, 2005 | 06:59 AM
RTW DC2R's Avatar
Default Re: Stock fuel presure on an ITR (Quad4CiViC)
» Search Results
Your search for stock fuel pressure returned 20 results.
Old Apr 21, 2005 | 07:01 AM
USDM EG's Avatar
Default Re: Stock fuel presure on an ITR (RTW)
i only got 2 and they didnt say anything about itr
Old Apr 21, 2005 | 07:02 AM
RTW DC2R's Avatar
search the archives under the ITR forum.
Old Apr 21, 2005 | 07:20 AM
USDM EG's Avatar
Default Re: (RTW)
thx i n ever knew about the archived files....
Old Apr 21, 2005 | 07:32 AM
ZygSpeed's Avatar
Default Re: (Quad4CiViC)
47-54 psi is what the manual says.
With I/H/E mine is now at around 60.
You really should check the A/F before just setting it at an arbitrary number, but 39 seems low.
Old Apr 21, 2005 | 07:35 AM
USDM EG's Avatar
Default Re: (zygspeed)
i think 39 is not what its set at now taht i think about it... i have a a/f gauge, and its always on rich.... even at idle.... ill look at it tonight when i get home....
Old Apr 21, 2005 | 07:46 AM
ZygSpeed's Avatar
Sorry I can't be of more help.
Is this a JDM or USDM motor?
Stock or with some bolt ons?
Old Apr 21, 2005 | 08:21 AM
USDM EG's Avatar
its a jdm 97 spec with fuel pressure upgrade, i/h/e, clutch flywheel intake manifold gasket, cam gears (0,0), 98 spec header 2.5 inch collector, 2.5 inch test pipe, apexi n1
Old Apr 23, 2005 | 03:37 PM
USDM EG's Avatar
Default Re: Stock fuel presure on an ITR (USDM EG)
yeha i checked the preessure, it was at 39 psi at idle, i turned it up to 40 psi at idle, and with the vacuum line off (uncontrolled/full throttle) its now set at 50 psi..... still seems a lil low sompared to all you guys....
Old Apr 23, 2005 | 03:47 PM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM EG &raquo;</TD></TR><TR><TD CLASS="quote"> ...and with the vacuum line off (uncontrolled/full throttle) its now set at 50 psi..... .</TD></TR></TABLE>
I forgot to mention that the line either needs to be pinched or taken off, sorry my bad.
You're right in the middle of the 47-54 psi (hose off) numbers.
I only needed to up the fuel pressure once we started playing with the cam gears on the dyno.
Old Apr 23, 2005 | 07:04 PM
USDM EG's Avatar
Default Re: Stock fuel presure on an ITR (zygspeed)
nice, if u dont mind me asking what kinda number u put down? and what degree are teh cam gears, cause i have fidanza gears and im gonna get my car dyno tuned in the spring....
Old Apr 23, 2005 | 07:20 PM
ZygSpeed's Avatar
Here's the last of the dyno plots.
DC 4-1 header, aftermarket cat, SMSP 2 1/2" double resonated exhaust with magnaflow small straight through muffler, Mugen intake, cam gears (I think the intake was retarded like 2 degrees ... not quite finished with them), stock ECU, AEM PPR. HTH Ed
Old Apr 23, 2005 | 07:49 PM
USDM EG's Avatar
what year spec itr? jdm, or usdm?
Old Apr 23, 2005 | 07:54 PM
ZygSpeed's Avatar
97 USDM #151 ... about 78K miles.
I've got a VAFC sitting around here, along with a test pipe and Mugen ECU for when I get some free $$ to get back down to Inline Pro for some work with the VAFC and ECUs.
Chubz
Aug 28, 2004 06:58 AM
mrtrex
Jun 2, 2004 04:31 PM
BryanSprinkel
May 16, 2002 09:55 AM
Hard2Find
Feb 20, 2002 11:06 AM
nsx-Animal
Sep 7, 2001 12:28 PM
