Oil in intake
please dont flame at me, its not your normal "after time there will be oil in the intake" im talking about large amounts of oil. because right now my intake is consuming a LOT of oil into the intake to the point where my HKS filter becomes drenched in oil in abut a few hours of driving (drenched from the bottom) when i take off the tube that goes from the crank case to the intake there is a LOT of vapor spewing out.. what could be the problem of this? has anyone experanced this problem?
-Tom
Modified by JDMcb7 at 8:47 AM 4/21/2005
-Tom
It sounds like you are having a problem with your crankcase ventilation system. If you are getting that much oil in your intake then I would check to make sure you have the correct oil amount in your motor. Also, have you checked the intake manifold to see if it is full of oil too?
Check your PCV valve or just replace it (they're like $3). You can squeeze the hose that is attached to the valve, if you hear it click shut then it works. Also make sure you don't have any vaccuum leaks.
Might check your compression if you're that ambitious and worried.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schmitey »</TD></TR><TR><TD CLASS="quote">Check your PCV valve or just replace it (they're like $3). .</TD></TR></TABLE>
PCV=crankcase ventilation
yea I know what PCV stands for...please don't insult my intelligence
not everyone knows what the valve does or that its even there
PCV valve seems okie.. when i take it out it rattles.. but i'll try to replace it anyways... oh man.... i hope thats the problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schmitey »</TD></TR><TR><TD CLASS="quote">yea I know what PCV stands for...please don't insult my intelligence
not everyone knows what the valve does or that its even there</TD></TR></TABLE>
I was not insulting your intelligence so chill out. Damn why does everyone take stuff so personally on here. the little
would show you that it was a comment to be taken with a grain of salt.
Here is a great diy for a catch can which can prevent oil going from your pcv into your intake manifold.
http://www.cb7tuner.com/vbb/sh...catch
I would replace your pcv valve and go from there like others have suggested
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .ken »</TD></TR><TR><TD CLASS="quote">Here is a great diy for a catch can which can prevent oil going from your pcv into your intake manifold.
.</TD></TR></TABLE>
Good link dude. I could not remember where I had seen that.
.</TD></TR></TABLE>Good link dude. I could not remember where I had seen that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -RedneckDave- »</TD></TR><TR><TD CLASS="quote">
Yea I did mine like 2-3 months ago and thus far have accumulated 2 full things of oil from the catch can; just to think all that WAS going into my intake manifold is enough to keep you up at night
It was very cheap as you can see too and it's a huge preventative thing for almost any car
</TD></TR></TABLE>Yea I did mine like 2-3 months ago and thus far have accumulated 2 full things of oil from the catch can; just to think all that WAS going into my intake manifold is enough to keep you up at night
.It was very cheap as you can see too and it's a huge preventative thing for almost any car
yea sorry man, i'm just wound up and ready to get the hell out of school for the summer!
Awesome write up!, I might have to yank some parts off of an old air compressor. Something tells me a cheap **** like myself might be able to weld something up as well, long as its airtight it shouldn't matter.
well... my motor is now toast... gotta tow it to the shop now
gosh darn it.... i guess its time for another swap... it wont retain any oil no more.. just spews out leaking now when i turn on my car..
could be? who knows.. blah i just want that motor out of my car.. got the worst of luck on that motor.... i guess 3rd motor will be the charm
it is not your balancer shaft seal if those leak you have an outer leak that can be noticed at lower timing belt cover not oil in the intake...silly question and not questioning your intelligence you chk oil to make sure it is not overfilled right? could be your valve seals leaking
no no no i never overfill myoil.. acutally its no oil at all now.. mind you once i start my car.. all the oil comes out.. ... oh well.. swap #2 is on its way.. just picking up my Exedy flywheel and hopfully i should have my new motor in by tuesday :D
