......................what size is this for me to use an fittings???????????????????????????
Old Apr 20, 2005 | 11:34 PM
drift2004's Avatar
Default ......................what size is this for me to use an fittings???????????????????????????
i am using steel braided lines so i need to know what size for an 1991 integra iim thinbking it might be a 3an not sure.
Old Apr 20, 2005 | 11:45 PM
BlueShadow's Avatar
Default Re: ......................what size is this for me to use an fittings??????????????????????????? (dr
I believe a 5AN line/fitting is the one you need or maybe 6AN will work too. The fuel hose line is 5/16" which is 5AN. But I may have read that 6 AN works too.
let me see if I can find some old posts about it. If I dont post back up try IMing Bryson. He recently changed his fuel lines to SS, maybe he can tell you what size line he used.
EDIT: you can also try contacting Flamenco-T to see what he has in stock. I think whether you have a stock fuel rail or aftermarket makes a difference in what AN size you use.
https://honda-tech.com/zerothread?id=1011936
Old Apr 21, 2005 | 02:38 AM
acurar0ss's Avatar
you need a banjo fitting with a 6 an end...... and if you are using a stock fuel rail you need a banjo fitting for that as well.... if you dont have a stock fuel rail you can either use a banjo or go directly into the rail with a 6 an fitting.
Old Apr 21, 2005 | 02:45 AM
BoostedCivicSedan's Avatar
I think he means to eliminate that banjo fitting and get an AN adapter that goes straight into the filter... There was a write up on it somewhere... I will see if I can find it...
And yes, Stan/Flamenco T has the fitting you need....
Old Apr 21, 2005 | 03:55 AM
rudebwoy's Avatar
http://www.stealthmodeperformance.com has the complete lines for sale, he probable can tell you what size also.
Old Apr 21, 2005 | 04:55 AM
White Smoke's Avatar
i my honda
Global Mod
That threat pattern is NOT -an its NPT. You need a NPT to -6an or -5an adapter and -6an or -5an fittings and line.
Stan/User: Flamenco T knows the size and proly has the fitting in stock. PM Him
Old Apr 21, 2005 | 05:24 AM
TrueNorthStar's Avatar
Actually it is a metric thread. I think it is 12mm x 1.5. It could be 12mm x 1.25.
Old Apr 21, 2005 | 06:20 AM
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrueNorthStar &raquo;</TD></TR><TR><TD CLASS="quote">Actually it is a metric thread. I think it is 12mm x 1.5. It could be 12mm x 1.25. </TD></TR></TABLE>
That sounds about right but its still NPT
Metric or Standard it does not matter, its still National Pipe Thread.
Old Apr 21, 2005 | 08:29 AM
drift2004's Avatar
yes i want to take it out the banjo fitting thing completly i used a 6 an and its to big so i got to go try another small one. using aftermarket fuel rail, would a 8an line be to big?
Old Apr 21, 2005 | 09:02 AM
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drift2004 &raquo;</TD></TR><TR><TD CLASS="quote">yes i want to take it out the banjo fitting thing completly i used a 6 an and its to big so i got to go try another small one. using aftermarket fuel rail, would a 8an line be to big?</TD></TR></TABLE>
Yes. -8 is LARGER than -6! Pm "Flamenco T" for your fitting needs!
Old Apr 21, 2005 | 10:06 AM
Dee's Avatar
Dee
This is from ANplumbing.com but I ordered mine from Summit. The stock fuel rail uses the same size adapter.
991945 12mmx1.25 -6 Carburetor Adapter Solex, Dellorto, Mikuni $6.59
Crashoveride1913
Jul 16, 2008 12:31 PM
92DAturboteg
Dec 19, 2006 01:28 PM
wickedEFguy
Feb 9, 2006 08:43 AM
alfaaay
Jul 28, 2005 12:48 PM
turbotypeR@SPEC
Jan 29, 2002 02:01 PM
