Serial - USB adapter for motec.
Old Apr 20, 2005 | 11:26 PM
FastEK9's Avatar
Default Serial - USB adapter for motec.
Anyone here have a laptop without serial ports? and are using usb to serial adapter to tune there motec? i have a Sony laptop, I've got the keyspan adapter but it doesn't work to well... been having to use a friends older Dell with serial ports.
Old Apr 21, 2005 | 02:03 AM
James L.'s Avatar
Default Re: Serial - USB adapter for motec. (FastEK9)
I have use the USB to Serial adapter with both the sony and toshiba computer.... It works out great! There is a couple of different selection that can be purchase at best buy or Fly's Electronics if there is one over where you at... Oh, and make sure the USB Port that is taken the serial adapter is assign for the job. It won't work if you just plug in the adapter without setting it up. Good luck!
Old Apr 21, 2005 | 04:05 AM
GregGSC's Avatar
We use the one from Radio Shack it work great. Just set it up in all the ports. This way you can just plug in and go. Software comes on a disk though, so you have to put it on CD if you don't have a disk drive to install it.
John
Old Apr 21, 2005 | 04:44 AM
tony1's Avatar
Default Re: Serial - USB adapter for motec. (gscmotorsports)
Mine works fine, I don't even know what brand it is, I think i got it at Fry's. Maybe it's just you Minh. lol
Old Apr 21, 2005 | 05:04 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Serial - USB adapter for motec. (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Mine works fine, I don't even know what brand it is, I think i got it at Fry's. Maybe it's just you Minh. lol </TD></TR></TABLE>
Tony, this is why I asked you yesterday because Ive heard of this happening. I have the same problem with Autronic. Once you find an adapter that works keep it handy and buy an extra one.
art
Old Apr 21, 2005 | 05:18 AM
tony1's Avatar
Default Re: Serial - USB adapter for motec. (Arturbo)
I have 2 already
Old Apr 21, 2005 | 08:34 AM
danimal's Avatar
there is a big thread on serial/usb adapters for efi tuning on the megasquirt board: http://msefi.com/viewtopic.php?t=3410
Old Apr 22, 2005 | 12:37 AM
FastEK9's Avatar
Default Re: Serial - USB adapter for motec. (danimal)
Ive herd of the radio shack ones working, i guess imma give them a try. i have the keyspan one now it works great for other systems, but only the motec , yeah i have assigned the ports just not luck.. thanks for the help guys.
Old Apr 22, 2005 | 06:32 AM
atcrx's Avatar
I am using one from tiger direct. works great with the fast system.
Old Apr 22, 2005 | 07:00 AM
Kataku2K3's Avatar
Default Re: Serial - USB adapter for motec. (atcrx)
Yea, it's probably Minh... haha kidding kidding I just got a new one at Fry's the other day. It's a cheap $15 AirLink that I was extremely skepitcal about, but it ended up working. So far I've used it on my IBM laptop and friend's Toshiba with both Motec and FAST without any problems. I used to have a Keyspan that worked great when running an Emulator/Romulator for Hondata but it was always sketchy and sometimes had connections problems with other EMSs.
P.S. - Minh, you're still running M48 on your car, aren't you? I'm sure Tony knows but I haven't got to work with any of the Motec systems that run a parallel connection (I've seen it on Bergenholtz's car and Skunk's RSX so I figured it must be on the high end stuff! Yes/No Tony ). Straight serial is definately nice but hopefully you find an adapter that works so you can make use of your Sony.
Old Apr 22, 2005 | 08:50 AM
Suprdave's Avatar
Default Re: Serial - USB adapter for motec. (Kataku2K3)
Buy a Compaq Presario 2108CL...they are on Ebay new for like 700 bones. I have one and it came with a Serial...I was on the Hunt for a new Laptop that had serial for months...finally found this one at Costco for $1100 last August.
Old Apr 22, 2005 | 09:29 AM
JDogg's Avatar
Default Re: Serial - USB adapter for motec. (Suprdave)
i use a socketcom pcmcia-seral adapter. its alot faster than a usb adapter and dosnt flake out like the usb drivers for the 2 or 3 i usb adapters i used to have.
Old Apr 22, 2005 | 11:29 PM
FastEK9's Avatar
Default Re: Serial - USB adapter for motec. (JDogg)
Yeah its probly me.. i suck at life when it comes to computer's, everyone seems to have luck with the ones from Fry, we dont have that electronics store but i guess theres always online ordering..
Old Apr 22, 2005 | 11:35 PM
Arturbo's Avatar
Better than steak
25 Year Member
http://www.outpost.com is fryes...
Old Apr 23, 2005 | 05:47 AM
b19coupe's Avatar
My Dell Inpiron 1100 has no serial ports. I am using two Siig USB-to-serial adapters and they work well. I have a PCMCIA serial card and it does not work.
http://www.siig.com/product.asp?pid=252
chunky
Welding / Fabrication
27
Dec 11, 2010 09:32 AM
aalb1
Audio / Security / Video
Jun 30, 2009 12:05 PM
DeathLens
Dec 15, 2008 04:45 PM
.Kevin.
Jun 27, 2006 05:14 PM
jond
Aug 11, 2005 08:41 AM
