Two diffrent Distributors?
I posted a couple of days back putting a multi port engine 5sp from a 3 door into a 4 door auto! https://honda-tech.com/zerothread?id=1216243 The engines have diffrent distributors the multi port engine has more wires going into the distibutor I imagine this is to run the injectors I plan on using the TB injection on the auto, which wires do I need to delete to make this happen as i dont trust the dist on the baked engine!?Can anyone tell me?
Thanx
Fred
Thanx
Fred
The 2 extra wires on the distributor is for a sensor that the DX distributor doesn't have. If you are going to use the DX (DPFI) set-up, you need to use the DX distributor.
sodacan33
Apr 27, 2004 05:07 AM
Elmdale
Sep 14, 2002 07:01 AM
