whats your best ets on drag radials
Old Apr 20, 2005 | 07:55 PM
tony n.'s Avatar
Default whats your best ets on drag radials
whats your setup, car, how much u pushin
this would help me decide what motor i should go with...
i want a fast street car thats why im askin best time on drs
thx in advance!!
Old Apr 21, 2005 | 01:52 AM
turbotypeR@SPEC's Avatar
25 Year Member
Default Re: whats your best ets on drag radials (boosted2cam)
see sig
Old Apr 21, 2005 | 05:48 AM
tony n.'s Avatar
Default Re: whats your best ets on drag radials (turbotypeR)
damn thats nice what drag radials wur u runing? which one would u think would be faster on drag radials b16 or gsr? im plannin on buildin either motor
Old Apr 21, 2005 | 10:16 PM
zacdaddy77's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotypeR &raquo;</TD></TR><TR><TD CLASS="quote">see sig</TD></TR></TABLE>
I have to say you gotta be a hell of a driver (turbo "R") !
thats what makes up for money thats why I've beat two 99-2000' si's with my stock ls ( they catch me bout the time I hit 90)
Old Apr 21, 2005 | 10:51 PM
V-SPEC 1's Avatar
see sig
Old Apr 21, 2005 | 11:45 PM
james111's Avatar
bfg drag radial was tested to i believe a mid 8 second run...
we turned 10.98@125 with a 1.6 60' in the miata....400rwhp
paul efantis and others have used the same and had great success....
get em bald and second gear burn out will heat em up..
i went 13.5@109 with a fwd mx6 with 1.71 60' back in the day bout 300fwhp
tire should be no lower that 12psi....the balder the better we tested....
james
Old Apr 22, 2005 | 06:47 AM
One Cam's Avatar
Default Re: (Bean-Burrito)
Old Apr 22, 2005 | 07:39 AM
BoostR41's Avatar
Default Re: (One Cam)
see sig....full weight ITR with right around 300whp
Old Apr 23, 2005 | 03:52 AM
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted2cam &raquo;</TD></TR><TR><TD CLASS="quote">damn thats nice what drag radials wur u runing? which one would u think would be faster on drag radials b16 or gsr? im plannin on buildin either motor</TD></TR></TABLE>
i was using bfg 225-50-15.they were stil spinning across the finish line and it was hitting the rev limiter at 9500 right before the line.this year i have the 235-60-15 m/t.haven't used them yet.as far as what engine to build,bigger displacement will will be better,go with the gsr
Old Apr 23, 2005 | 10:33 AM
BoostR41's Avatar
i was using bfg 225-50-15.they were stil spinning across the finish line and it was hitting the rev limiter at 9500 right before the line.this year i have the 235-60-15 m/t.haven't used them yet.as far as what engine to build,bigger displacement will will be better,go with the gsr</TD></TR></TABLE>
lemme know how those MT's do. I want to run a radial tire so I can run power street but have something that hooks a bit better than the BFG's
Old Apr 24, 2005 | 08:25 AM
saleensolution's Avatar
hey danny if you need help getting those m/t's lemme know well trade goods for some knowledge
Old Apr 24, 2005 | 08:57 AM
tony n.'s Avatar
i think ive made my mind up...GSR
so the gsr has more of a powerband right fellas?
i have a wannabe 99si so i hope i get good times on drag radials with a build gsr!
the thing is i have a b16 head and will b puttin it on a gsr...does it lower the compression?
Old Apr 24, 2005 | 08:58 AM
tony n.'s Avatar
https://honda-tech.com/zero...23319
how come they said the b16 has a smaller displacement and have a better powerband im confused
Old Apr 24, 2005 | 11:19 AM
b16sedan's Avatar
Default Re: whats your best ets on drag radials (james111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by james111 &raquo;</TD></TR><TR><TD CLASS="quote">bfg drag radial was tested to i believe a mid 8 second run...</TD></TR></TABLE>
Best on BFG's are some 7.9X's, best ever on radials is Rick Head, 7.66 on Mickey Thompson radials. You don't run 3 tenths quicker just by changing tires in a fluke accident., the MT's are a much better hooking tire.
Old Apr 24, 2005 | 02:40 PM
tony n.'s Avatar
Default Re: whats your best ets on drag radials (b16sedan)
wat are mts
Old Apr 24, 2005 | 03:36 PM
b16sedan's Avatar
Mickey Thompson ET Street Radials
Old Apr 24, 2005 | 06:33 PM
25 Year Member
Default Re: whats your best ets on drag radials (saleensolution)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saleensolution &raquo;</TD></TR><TR><TD CLASS="quote">
hey danny if you need help getting those m/t's lemme know well trade goods for some knowledge </TD></TR></TABLE>
what?who is this? shoot me an im
Old Apr 25, 2005 | 03:35 AM
what?who is this? shoot me an im</TD></TR></TABLE>
got ya
Old May 1, 2005 | 10:43 AM
swapit's Avatar
225/50-15 BFG went 11.43 at 128mph wit 1.81 sixty foot.spinning 1st,2nd,and into 3rd.still love the tire on the street.do wonders wit track bit on the street.
Old May 1, 2005 | 03:34 PM
tony n.'s Avatar
Default Re: whats your best ets on drag radials (swapit)
whats your setup? car?
Old May 1, 2005 | 04:25 PM
rondigs's Avatar
see sig
Old May 2, 2005 | 08:51 AM
deftones0817's Avatar
Default Re: whats your best ets on drag radials (rondigs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted2cam &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zero...23319
how come they said the b16 has a smaller displacement and have a better powerband im confused</TD></TR></TABLE>
go with a gsr its worth it and you wont be disappointed. There is no replacement for displacement...
Old May 2, 2005 | 01:58 PM
tony n.'s Avatar
Default Re: whats your best ets on drag radials (deftones0817)
what about put a gsr crank in that homo and b ready to go
Old May 2, 2005 | 04:00 PM
SlowWhiteEvo's Avatar
12.7@109. 1994 SI with very mild wieght reuction. JDM b18c and 7 lbs of boost. 205/50/15 bfg's
Old May 2, 2005 | 06:12 PM
Bulldogg83's Avatar
Default Re: whats your best ets on drag radials (SlowWhiteS2K)
12.2@119mph in 1/4 on BFG 205/50/15 G Forces...best 60ft 1.91
7.84@94mph in 1/8th on BFG 225/50/15 G Forces...best 60ft 1.84
2000 Civic Si that weighted 2560 with me, but no AC/Cruise Control. Car made 396whp/268ftlbs @ 17lbs on 84.5mm B16.
