f2 forks what years work?
hey guys, i need a new set of forks(or just one) and am wondering what years i can look through? are f3 forks exactly the same? i did a search and couldnt find anything.
F2/3 forks are the same diameter but the F2 forks are longer. If you're going to get F2 forks make sure you get the '94 and up forks since they are cartridge forks
91-94 forks for f2.
If you wanted to go to f3 forks you would have a few problems. F3 rims have floating rotors, f2 does not. The diameter is different if I am not mistaken so the mounting position/location of the brake calipers are different. The left lower fork does not have the tabs to hold/lock the speedo unit in place and the front fender mounts differently. Stick with the f2 forks unless you want to customize a bunch of stuff.
94 forks are better as previously mentioned.
Steven
Steven
project-boosteD
Jan 24, 2006 03:51 PM
