Got slicks mounted on Bogarts. Balancing??
Old Apr 20, 2005 | 07:15 PM
anothaRRR's Avatar
Default Got slicks mounted on Bogarts. Balancing??
So today I got my Bogarts in and took them to a shop to get my slicks mounted on them. When we balanced them it took alot of weights to get it to zero out. Is this normal?? We used stick on weight on the inside and outside, and the wheels are brand new. I know you can change it to static and some other types, which one is the one I should use. Thanx alot..
Old Apr 20, 2005 | 08:08 PM
T4eg's Avatar
Default Re: Got slicks mounted on Bogarts. Balancing?? (anothaRRR)
i use aluminum setting 7 (1weight on the inside lip) on my machine at work. My bogarts (skinnies) took .25 - .5 to balance out.. and what do u consider "alot of weight"
Chris
Modified by BlueHatch00 at 12:59 AM 4/21/2005
Old Apr 20, 2005 | 08:23 PM
anothaRRR's Avatar
Default Re: Got slicks mounted on Bogarts. Balancing?? (BlueHatch00)
It probably took like 2.25 on the outside and like 1.75 on the inside, im gonna change the setting on the machine and redo them tomorrow.
Old Apr 20, 2005 | 08:34 PM
SlicksMH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anothaRRR &raquo;</TD></TR><TR><TD CLASS="quote">It probably took like 2.25 on the outside and like 1.75 on the inside, im gonna change the setting on the machine and redo them tomorrow. </TD></TR></TABLE>
You have nothing to worry about anothaRRR, that is normal.
Good Luck.
John@M&H-Hashims
Old Apr 21, 2005 | 04:29 AM
1 2 NV's Avatar
Default Re: Got slicks mounted on Bogarts. Balancing?? (SlicksMH)
i dont balance any of my slicks because they are bias ply tires and will get "flat" spots on them from sittin with weight on them. my car is on jackstands right now as a matter of fact.
Old Apr 21, 2005 | 04:31 AM
VisualAutoMotoring's Avatar
Default Re: Got slicks mounted on Bogarts. Balancing?? (1 2 NV)
Just from experience, once the tire pressure changes it knocks the balance off.
Use stick-on weights and then put duct tape on top of it
Old Apr 21, 2005 | 04:55 AM
anothaRRR's Avatar
Default Re: Got slicks mounted on Bogarts. Balancing?? (Hybrid-Performance.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid-Performance.com &raquo;</TD></TR><TR><TD CLASS="quote">Just from experience, once the tire pressure changes it knocks the balance off.
Use stick-on weights and then put duct tape on top of it</TD></TR></TABLE>
We used stick on weights and had some wide chrome tape so thats what we used to tape the weights down. Thanx guys.
ForceFed Motorsports
Northwest
Apr 28, 2008 11:53 AM
megotvtec
Apr 12, 2005 10:03 AM
Ryan C
Aug 22, 2004 04:43 PM
ridnmyhonda
May 18, 2003 12:34 PM
egg
May 12, 2003 06:11 PM
