ITR 5-lug suspension swap into EK/EJ Civic
Old Apr 20, 2005 | 07:09 PM
xkwzt21's Avatar
Default ITR 5-lug suspension swap onto EK/EJ Civic
Okay, from all the looking at various posts on honda-tech I think I have figured out most if not all of the parts I will need to do this swap on my '96 Civic 4 door. Keeping in mind that I have disc brakes up front and drums in the rear.
Parts list from an ITR:
Front hub/knuckle assembly (x2)
Rear trailing arm assemby (x2)
New brake lines (probably stainless steel at all 4 corners)
New brake pads (at all 4 corners)
5-lug rims
If its JDM then you need 36mm axles, if its USDM you need 32mm axles.
The rest of these parts I have seen in some posts but nothing has been an absolute must have, please correct me if I'm wrong. What car do I need all of the below mentioned parts from?:
Brake booster
Master Cylinder
40/40 Proportioning Valve
E-brake cables
Modified by xkwzt21 at 2:35 PM 4/21/2005
Old Apr 21, 2005 | 10:35 AM
xkwzt21's Avatar
Default Re: ITR 5-lug suspension swap onto EK/EJ Civic (xkwzt21)
somebody help me please!
Old Apr 21, 2005 | 11:38 AM
poison's Avatar
You've listed all the parts correctly for what you need for the swap.
The master cylinder, you will need to retain the 15/16" master cylinder from a 94-01 Integra RS. This is due to it being non-ABS and will directly bolt in with your current brake lines.
The brake booster will work from any 94-01 Integra as well. Same with the prop valve. As for e-brake cables I would get them from a 99-00 Si.
Good luck.
Old Apr 21, 2005 | 05:42 PM
xkwzt21's Avatar
Default Re: ITR 5-lug suspension swap onto EK/EJ Civic (poison)
Thanks for the help, I appreciate it.
cnydc2
11
Mar 6, 2008 02:55 PM
abusedhusband
Suspension & Brakes
May 30, 2007 10:28 AM
whole9
10
Mar 30, 2007 10:00 PM
xkwzt21
Apr 21, 2005 11:16 AM
jefe
Nov 21, 2004 02:54 PM
