K24 Swap
Old Apr 20, 2005 | 07:05 PM
dtrtw's Avatar
Default K24 Swap
Hey guys i just wanted to know what i would need to do the k24 swap i found a sweet deal on a k24 engine seller is also on this forum need to know what parts would i need to complete thanks going into a 94 integra thanks
Old Apr 20, 2005 | 07:07 PM
Kendall's Avatar
Pretty much the same stuff as you would need for any K20 swap. Do some research and talk to some of the people who are familiar with K series swaps (for example: brian g).
Old Apr 20, 2005 | 07:11 PM
marsbike's Avatar
From: Salt Lake City, Chicago at heart, UT or IL, USA
Default Re: (Kendall)
be aware that it'll put even more weight foward in the car, making it much more nose heavy.
Old Apr 20, 2005 | 07:17 PM
InLimbo87's Avatar
Default Re: (marsbike)
not sure on the facts behind this one, but isnt the k20 quite similar in weight to the average b-series?
Old Apr 20, 2005 | 07:19 PM
KhanhCord's Avatar
Default Re: K24 Swap (dtrtw)
if u use the k24 engine, then u must use the k20 6 speed trans.
Old Apr 20, 2005 | 07:26 PM
psychotic_z's Avatar
Default Re: K24 Swap (KhanhCord)
Or the K24's 5-speed
Old Apr 20, 2005 | 07:27 PM
KhanhCord's Avatar
Default Re: K24 Swap (psychotic_z)
try using k24 trans and see
Old Apr 20, 2005 | 07:42 PM
marsbike's Avatar
Default Re: (tegsedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegsedan &raquo;</TD></TR><TR><TD CLASS="quote">not sure on the facts behind this one, but isnt the k20 quite similar in weight to the average b-series?</TD></TR></TABLE>
yeah, close in weight, but, the engine sits very far foward in the engine bay.
Old Apr 20, 2005 | 07:44 PM
MikeTV
Guest
Posts: n/a
1. The K24s head sucks ***.....iits not worth it unless you are going ot mate it to a k20a or k20a2 head.
2. If your suspension isnt dialed in, the amount of torque that the k24 has will give you big time traction problems.
Old Apr 20, 2005 | 07:50 PM
dtrtw's Avatar
Default Re: (Eclipse spanker)
damn i can never win i have a LS poeple need to know what to do to gain some power so i wont have to lose the majority of my races thanks
Old Apr 20, 2005 | 07:57 PM
E-Rok's Avatar
EPIC TUNING
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KhanhCord &raquo;</TD></TR><TR><TD CLASS="quote">try using k24 trans and see </TD></TR></TABLE>
5 speed K24 tranny works, 6 speed TSX does not.
Old Apr 20, 2005 | 08:29 PM
DC4KiD's Avatar
Default Re: (dtrtw)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dtrtw &raquo;</TD></TR><TR><TD CLASS="quote">damn i can never win i have a LS poeple need to know what to do to gain some power so i wont have to lose the majority of my races thanks </TD></TR></TABLE>Tear your motor apart and build it to withstand 20psi of b00st.
Old Apr 20, 2005 | 09:25 PM
dtrtw's Avatar
Default Re: (DC4KiD)
was planning to but figured it would cost me about 6000
Old Apr 20, 2005 | 10:27 PM
RidinStock's Avatar
Default Re: (dtrtw)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dtrtw &raquo;</TD></TR><TR><TD CLASS="quote">was planning to but figured it would cost me about 6000 </TD></TR></TABLE>
Eh... k-series swap probably won't be as inexpensive as you think. Then again, I've never researched it, but I'm sure it takes some good fab work.
You don't have to boost 20 lbs, hell, if the stock block is good then tune it at 10-12psi and you will take care of most of your races. Then, down the road if you get serious you could build up the block.
Old Apr 20, 2005 | 10:32 PM
DAguyLS's Avatar
yea I agree with RidinStock
Even if you can obtain a K for a deal, you'll still be spending a shitload of money in the end.
So you'd be smarter just replacing some of the internals and boost it. And I wouldn't try to shoot for 20psi on your first turbo'd whip. Start out easy and work up from there. You'll learn more in the process that'll help you when your reaching for 300+hp.
Old Apr 21, 2005 | 06:32 AM
MikeTV
Guest
Posts: n/a
Default Re: (slamdLScivic)
keep it simple..if you want to go fast but dont have alot of $$$, n0000ssss
Throw a 50 shot on it and you will be all set.. my buddy throw a 75 shot on his ls and ran a high 13 sec. pass at the track
diversity210
35
Jun 13, 2010 07:07 AM
hondachance
31
Jul 26, 2008 10:46 AM
HondaTeKnology
Jan 11, 2008 08:38 AM
Dc4turbo408
Jun 3, 2005 06:37 PM
