Ebrake sticking BAD...how to fix
Old Apr 20, 2005 | 06:27 PM
Mag00n's Avatar
Default Ebrake sticking BAD...how to fix
My ebrake is sticking BAD on driver rear wheel. Its burning up pads bad. It takes about 45minutes to release if I just let it sit. What should I look for to rectify this problem?
Old Apr 22, 2005 | 12:44 PM
Mag00n's Avatar
Default Re: Ebrake sticking BAD...how to fix (Mag00n)
Thanks for the help guess I shoulda asked if I could put a b16 in an EF and how fast it will be
Old Apr 22, 2005 | 12:56 PM
EJ2-Fluffy's Avatar
maybe your slave cylinder is sticking in the back? Maybe its time to take them apart and put them back. I know that has nothing to do with the E brake but it couldn't hurt to inspect.
Also, how about the spring and lines themselves? maybe you need to replace them?
Hopefully that helps.
-Jon
Old Apr 22, 2005 | 01:31 PM
CRXVTEC69's Avatar
no, if you have drums in the rear (I am assuming here) check the E brake cable lossen it or tighten it or maybe loosen up the shoes??
Old Apr 22, 2005 | 01:43 PM
Deetz's Avatar
Crazy Honda Guy
You may need to either get new e-brake cables, or if its a rear disk set up a caliper may be seizing up.
Old Apr 22, 2005 | 01:46 PM
Mag00n's Avatar
Default Re: (Deetz)
It is rear disk but it only seizes when the ebrake is used...does that make sense?
bopbop93030
Jul 7, 2008 12:26 AM
AzCRX
Apr 17, 2007 06:18 PM
Pishpeng
26
Feb 5, 2007 08:09 AM
PreludePhill
May 5, 2006 07:22 AM
Lei Siew Long
Jun 20, 2002 05:38 AM
