JDM .v. USDM ECU's?
Old Apr 20, 2005 | 06:26 PM
DarkTeg94's Avatar
Default JDM .v. USDM ECU's?
Other that the performance advantage for the JDM ECU, is it okay for me to run a p30 JDM ecu with a Skunk2 chip on my ls/vtec set up?
It is also socketed, does this mean that if I want to change my program from Skunk2 to Jun or something like that, that I can? And my ecu would need to be socketed to run a program like hondata correct?
Old Apr 20, 2005 | 06:37 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: JDM .v. USDM ECU's? (DarkTeg94)
Well if it's anything like my friend's JDM ITR ecu, it has the VTEC switch built into the ECU, because the JDM ITR engine does not have the VTEC switch on the engine head like USDM cars do. Also the JDM ECU will have a speed limiter of something like 180 kph
Old Apr 20, 2005 | 06:43 PM
DarkTeg94's Avatar
Default Re: JDM .v. USDM ECU's? (PatrickGSR94)
So then, does this mean that this ECU won't work with my ls/vtec install. It's a b16a2 usdm head.
Old Apr 20, 2005 | 06:48 PM
Community Builder
I'm not sure... if the VTEC switch is built in, then it may not interface with the USDM VTEC setup. It might require a JDM VTEC solenoid. I don't know for sure though.
But why a JDM ECU? Anything that ECU can do, a chipped P28 can surely do and probably more, and there will be no problems wiring up VTEC or having a speed limiter or anything like that.
phoxking
Mar 25, 2011 12:04 PM
meheartmycivic
Sep 1, 2010 11:13 PM
meheartmycivic
Aug 17, 2009 08:39 PM
Luke G.
Engine Management and Tuning
Jul 23, 2009 07:32 AM
insomniac791
Oct 8, 2005 04:52 PM
