need help with 4 wire 02 sensor
Old Jan 30, 2002 | 08:54 PM
b18c-93's Avatar
New User
Default need help with 4 wire 02 sensor
did a b16a swap in a 92 civis hatch cx. can somebody here show me how too do a 4 wire convershion compared too a 1 wire i would really app.
Old Jan 30, 2002 | 11:26 PM
Kamin's Avatar
Default Re: need help with 4 wire 02 sensor (93gsb16a)
um 1 wire?
shouldnt it have 2?
i could be wrong dont hate me.
Old Jan 31, 2002 | 06:31 AM
rainforest's Avatar
Default Re: need help with 4 wire 02 sensor (KAMiN)
no the eg's except the vx have 4 wire o2's and the vx has a five. I have never seen a one wire o2 conversion fill me in here?
Old Jan 31, 2002 | 08:04 AM
EE_Chris's Avatar
Default Re: need help with 4 wire 02 sensor (rainforest)
One wire O2's have been around a long time. 4 wire O2's provide better emmisions since the O2 is heated and starts working sooner, thus throwing the ECU into closed loop sooner. If you want to use a 4 wire O2, you need an ECU that uses a 4 wire O2. 2 of the wires are the signal & gnd, but the other two are for the heater section, which is controlled by the ECU. You should not attempt to use a 1 wire O2 with a 4 wire O2 ECU....you'll get codes.
Old Jan 31, 2002 | 03:17 PM
salbaje's Avatar
you did a b16 swap which exhaust manifold did you use. if you need help wiring your 02 let me know i can try to help you out
Old Feb 1, 2002 | 02:56 PM
Kataku2K3's Avatar
Default Re: need help with 4 wire 02 sensor (salbaje)
yea when i dropped my friends B16A into his 93 dx i had to rewire it for a 4 pin O2 sensor. I hate that single wire poo poo, besides the P30, P28, and P72 are not goin to run very well with that poo poo. No air/fuel signal to comp. E-mail me for ECU pinouts.
turbostd
Dec 4, 2008 04:03 PM
hksdrager
May 11, 2007 07:55 PM
lv6l
Dec 14, 2005 04:04 PM
egizzle8
Feb 16, 2004 10:09 AM
BeeT
Jul 7, 2001 05:42 PM
