01 Accord A/C wont work
Old Apr 20, 2005 | 05:42 PM
jhelmick's Avatar
Default 01 Accord A/C wont work
All the sudden (as usual) my A/C compressor clutch will not engage, checked power to the clutch and get ZERO volt DC when it should operate, cant seem to locate a bad fuse, maybe a power relay but cant locate that if there is one, is there anything else to cause the compressor not to run??IE a low pressure switch or something like that.
Old Apr 20, 2005 | 06:43 PM
Hondaaccordvtec's Avatar
Default Re: 01 Accord A/C wont work (jhelmick)
If you have a leak and all the r134 oil is gone, the ac compressor will not engage to save wear on the compressor.
Get a dye test done to your ac system.
Old Apr 20, 2005 | 08:28 PM
Stripped Honda's Avatar
99-0104
Default Re: 01 Accord A/C wont work (Hondaaccordvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondaaccordvtec &raquo;</TD></TR><TR><TD CLASS="quote">If you have a leak and all the r134 oil is gone, the ac compressor will not engage to save wear on the compressor.
you got it wrong ... there is a pressure sensor that senses if your system still has a proper amout of freon and if it is low it will not allow the compressor to turn on ... so first thing is to take it to a ac shop and ask them to check the system and they will usually tellyou what the problem is
Old Apr 21, 2005 | 03:32 AM
H2290's Avatar
Default Re: 01 Accord A/C wont work (Stripped Honda)
Didn't he say the same thing? No pressure, no turn on.
Old Apr 21, 2005 | 08:01 AM
YeuEmMaiMai's Avatar
you both got it wrong. The system will cycle on and off if there is not enough pressure for the system to operate. You might have a bad control unit.
Old Apr 21, 2005 | 09:12 AM
hypnosisracing's Avatar
Default Re: (YeuEmMaiMai)
Yes...it will go into a safe mode cycle and just continuously try to turn on and then phase off. I would just suggest bringing it to a trusted shop or perhaps a dealer, they are probobly going to rape you with labor cost, but perhaps they can give you some in depth insight to what you could do to completely fix it...typically if its low on freon, it doesnt just stop all of the sudden, you have times when its not cold and times when its EXTREMELY cold, you also have alot of moisture which can blow into the car, even with the windows up. A/C systems are such a pain sometimes.
Old Apr 21, 2005 | 10:24 AM
Default Re: (hypnosisracing)
He stated that his clutch is not engaging so I believe that the problem lies in the control unit (it is not telling the AC to turn on. There is a possibility that the pressure switch is bad but if it was the system will still cycle on and off.
Old Apr 21, 2005 | 11:06 AM
This is true...but it also seems like he's kinda going at it blind with no real a/c work experience, so diagnosing it with certainty will probobly not be too easy...since he didnt know this already, which is why i was saying atleast have them tell him what is wrong with it exactly...then if he wants to try to repair it he can, but atleast he'll know for sure.
Old Apr 21, 2005 | 12:54 PM
jhelmick's Avatar
I appreciate all of your help, I have a feeling its going into the shop, My expertise stops at checking to see if there is power to the clutch when the AC (should) be on. Obviously there is no voltage, which tells me one of several things: dash switch, fuse, relay, pressure switch....you name it, more than I can figure out. Thanks again
Old Apr 21, 2005 | 12:55 PM
matt_in_sd's Avatar
There is a relay in the underhood fuse box for the ac compressor, also fuse 58 feeds this relay and in turn the ac compressor clutch. Beyond this the trouble shooting gets complicated.
CG01
Engine Management and Tuning
Nov 7, 2012 08:18 PM
adam_n_tg
Sep 12, 2011 10:01 PM
imjustagirl
Aug 19, 2007 08:54 PM
dynamo
Jun 9, 2006 09:05 PM
shannon
Feb 6, 2004 10:03 AM
