OBD0 --> OBD 1 Conversion
Old Apr 20, 2005 | 05:21 PM
chem1imb's Avatar
Default OBD0 --> OBD 1 Conversion
How hard is it to do it if you buy the conversion harness...is it just plug up and bam or is it more than that? thanks in advance
Old Apr 20, 2005 | 06:20 PM
eda6's Avatar
Default Re: OBD0 --> OBD 1 Conversion (chem1imb)
It's easy. Took about an hour to install the obd1 distributor, 4 wire o2 sensor, conversion harness, ecu and start the car. Took two more hours to adjust timing, install heatshrink tubing an solder all the wires.
Modified by eda6 at 7:41 PM 4/20/2005
Old Apr 21, 2005 | 07:33 PM
Blown90hatcH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chem1imb &raquo;</TD></TR><TR><TD CLASS="quote">How hard is it to do it if you buy the conversion harness...is it just plug up and bam or is it more than that? thanks in advance</TD></TR></TABLE>www.JKobd.com Comes with full detailed instructions for an easy installation.
jakscivic
Sep 10, 2006 06:57 PM
jakscivic
Aug 23, 2006 06:34 PM
Expletive!
Oct 22, 2005 12:35 PM
PHOBIA
Jan 19, 2005 08:46 PM
91lsteg
Jan 9, 2005 11:43 AM
