car doesnt start right when parked on an incline
Old Apr 20, 2005 | 04:24 PM
inane's Avatar
Default car doesnt start right when parked on an incline
searched already...
i noticed this over the last month or two... when i park in my gfs driveway, the driveway is at a slight incline uphill... when i go to start the car, it turns once and then makes that sound the starter makes when you try to turn the key and the car is already running... that awful screeching sound... but the car isnt started yet... it makes that screeching a couple times when turning and 'then' the car will start...
if im parked on level ground... the car always starts perfectly in one to two turns...
thanks in advance
Old Apr 20, 2005 | 05:22 PM
2-7offsuit's Avatar
Default Re: car doesnt start right when parked on an incline (inane)
Do you have a JDM flywheel and a US starter? I had that same problem in my old CRX with a Spoon flywheel. Although I don't think that it would have anything to do with being on an incline.
Old Apr 20, 2005 | 05:30 PM
turbo_b16_ex's Avatar
maybe one of your bolts is loose that hold up the starter. that would make some since, once it hits incline it might be turning it
Old Apr 20, 2005 | 05:52 PM
inane's Avatar
Default Re: car doesnt start right when parked on an incline (2-7offsuit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2-7offsuit &raquo;</TD></TR><TR><TD CLASS="quote">Do you have a JDM flywheel and a US starter? I had that same problem in my old CRX with a Spoon flywheel. Although I don't think that it would have anything to do with being on an incline.</TD></TR></TABLE>
everything on my car is usdm... my flywheel has been resurfaced but its just a regular flywheel...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo_b16_ex &raquo;</TD></TR><TR><TD CLASS="quote">maybe one of your bolts is loose that hold up the starter. that would make some since, once it hits incline it might be turning it</TD></TR></TABLE>
i'll look into that tomorrow when its daylight again
VM 2
Mar 17, 2009 04:12 AM
DC4 Rasta
Aug 30, 2007 10:38 AM
SalmanzCivic
Jan 4, 2005 09:14 PM
94si94cx
Jul 28, 2003 09:37 AM
BlackGSR
Oct 3, 2001 06:38 PM
