Will 2001 stock Integra struts fit my 2000 Civic SiR?
Old Apr 20, 2005 | 01:27 PM
B16A2-EM1's Avatar
Default Will 2001 stock Integra struts fit my 2000 Civic SiR?
Are they a perfect match? Going back to stock ride height,
Thanks!
Old Apr 21, 2005 | 06:37 AM
B16A2-EM1's Avatar
Default Re: Will 2001 stock Integra struts fit my 2000 Civic SiR? (B16A2-EM1)
Wow, anyone know?
Old Apr 21, 2005 | 08:05 AM
onefstek's Avatar
they should fit. its the same as far as I know.
as long as they are not from an ITR then the rear will work with your SIR rear lca's.
Old Apr 21, 2005 | 08:37 AM
B16A2-EM1's Avatar
Default Re: (98ctr aka onefstek)
Thanks!
Also another guy has a full set of 4 struts off a 98 Civic, will those work as well?
Old Apr 21, 2005 | 08:45 AM
pdiggitydogg's Avatar
Integras are going to be a little bit different (I can never remember if theyre too narrow or too fat....either way they need to be shimmed or ground down a bit in the rear. Someone probably remembers which it is.
The ones off the 98 would be perfectly matched to the sir.
Either will work fine though
Old Apr 22, 2005 | 12:23 PM
B16A2-EM1's Avatar
Default Re: (pdiggitydogg)
Is it alot of work to grind them down? My cousin has a brake shop so I guess it shouldn't be a problem.
Old Apr 22, 2005 | 12:34 PM
Er Well not the shocks, the metal on the lca bushing.
Damn I wish I could remember which it is....shim or grind....
madclown
Suspension & Brakes
Apr 26, 2010 05:48 AM
showcivic2001
Jun 16, 2008 11:44 AM
nautica_t
Aug 8, 2003 12:52 PM
