Removing paint off GSR blades and polishing it???!!!!!!!
Old Apr 20, 2005 | 09:49 AM
vg7z's Avatar
Default Removing paint off GSR blades and polishing it???!!!!!!!
ok so im trading my painted GSR blades for some LS rims, act clutch and aem cam gear...the guy im trading em to wants to polish em
i know how to get the paint off with aircraift remover
when i painted the rims i sanded em down pretty good so its pretty rough from sanding...i started off with 400 then ended with 800
my question is will a polishing compound such as eagle one never dull or mothers fill in the sanding marks? i dont want the guy to be all pissed off
Old Apr 20, 2005 | 10:00 AM
Rpizzle's Avatar
Default Re: Removing paint off GSR blades and polishing it???!!!!!!! (vg7z)
You messed up on this one bro, the sand marks will nt come out.
Old Apr 20, 2005 | 10:22 AM
vg7z's Avatar
really? but in the polishing tutorials it says ur suppose to sand em down with 400 dry then 800 wet 1000 1200 1400 1500 then use a polish compound
Old Apr 20, 2005 | 10:30 AM
Rpizzle's Avatar
Default Re: (vg7z)
you can try it, it may take them out a little, but you will still be able to see them, someone correct me if Im wrong.
Old Apr 20, 2005 | 02:04 PM
vg7z's Avatar
help plz im tryin to be a good seller
Old Apr 20, 2005 | 02:10 PM
redlinetuning's Avatar
Default Re: (vg7z)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vg7z &raquo;</TD></TR><TR><TD CLASS="quote">really? but in the polishing tutorials it says ur suppose to sand em down with 400 dry then 800 wet 1000 1200 1400 1500 then use a polish compound</TD></TR></TABLE>
right.. just wet sand with 1000 and go up from there until smooth and then just use the polish compound. it will work. it'll take some work and a lot of time..
Old Apr 20, 2005 | 02:13 PM
dinko's Avatar
Default Re: (redlinetuning)
lol sounds like so much work!
fhukingviet
Sep 24, 2010 01:59 PM
mr_ek9
Feb 28, 2007 11:41 PM
sniperslayer
Nov 10, 2004 10:11 AM
Rasta
Jan 5, 2004 03:22 AM
redrex
Sep 14, 2003 12:27 PM
