wiring b18 and zc the same???
Old Apr 20, 2005 | 06:54 AM
integramic's Avatar
Default wiring b18 and zc the same???
I did a seach and found a really good wiring diagram for a zc but didn't know if the b18 was the same....Please let m eknow. Thanks.
Old Apr 20, 2005 | 07:04 AM
whowanrun's Avatar
Default Re: wiring b18 and zc the same??? (integramic)
yes the wiring is basically the same you are converting whatever harrness you have into a si harrness. it is just the four wires that run into the car are diffrent. Also if your moto is a vtec moto you have those wires to run inside also. Go to the hasport website under instructions. Good luck.
Old Apr 20, 2005 | 07:10 AM
EP3_05's Avatar
Depends on which b18 and OBD version you are talking about.
Old Apr 20, 2005 | 09:22 AM
integramic's Avatar
Default Re: wiring b18 and zc the same??? (91civic)
B18A OBD0 INTO 91 DX
Old Apr 20, 2005 | 04:31 PM
mar778c's Avatar
Community Builder
Community Influencer
Yes, basically the same.
Old Apr 20, 2005 | 04:37 PM
Ronin150's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c &raquo;</TD></TR><TR><TD CLASS="quote">Yes, basically the same.</TD></TR></TABLE>
It's all the same....I didn't pay attention and bought a 90-91 act clutch kit and obd0 ecu and I have the obd1 motor. IF you need those parts pm me. Good luck with the wiring.
Old Apr 20, 2005 | 05:44 PM
integramic's Avatar
Can I use the pr4 or do I need to use the pm6 or something like that...
Old Apr 20, 2005 | 06:25 PM
EP3_05's Avatar
Default Re: (integramic)
PR4 will work just fine
josh760
Apr 12, 2010 05:32 PM
91tealhatch
Aug 7, 2006 10:17 AM
civicrick
Apr 21, 2004 04:34 PM
civicrick
Apr 21, 2004 01:42 PM
Ronin Panda
Jun 7, 2003 05:32 AM
