***Genereal Integra questions***
Old Apr 20, 2005 | 05:41 AM
japspecnegro's Avatar
Default ***Genereal Integra questions***
1. When using Type R door panels on a 94 RS are you able to wire up power doors or is the wire non existent to wire power doors because my stock 94 RS door panels dont have em on there but it has power windows?
2. I am being told that if i decided to go with a JDM ITR cluster that my fuel indicator will not work for some reason. If that is so would i have to pull out the whole dash wiring harness out of a 98-up integra in order to get it to work or whats my other option(s)?
Old Apr 20, 2005 | 06:11 AM
b20turboteg's Avatar
Do you want the type r cluster for looks or for speed reasons? I have a 94 rs and i use a gsr with red bulbs and it looks just like type r just no 10000 rpm but dont need it
Old Apr 20, 2005 | 06:46 AM
Default Re: (b20turboteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20turboteg &raquo;</TD></TR><TR><TD CLASS="quote">Do you want the type r cluster for looks or for speed reasons? I have a 94 rs and i use a gsr with red bulbs and it looks just like type r just no 10000 rpm but dont need it
for both actually i was lookin to rev up to 9000. I wanted the Spoon DC2 cluster but my pockets arent that deep yet.
Old Apr 20, 2005 | 07:18 AM
Racermech's Avatar
Default Re: (japspecnegro)
First off i hope you are builing the motor up to rev to 9000rpm.
Second I have heard about changing the green film(?) on the cluster for everything it work. Do a search for genn film, or green backing see what you come up with
Old Apr 20, 2005 | 08:52 AM
Default Re: (Racermech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racermech &raquo;</TD></TR><TR><TD CLASS="quote">First off i hope you are builing the motor up to rev to 9000rpm.
Second I have heard about changing the green film(?) on the cluster for everything it work. Do a search for genn film, or green backing see what you come up with</TD></TR></TABLE>
its a some what built motor but hmm this green film, where on the cluster is it?
Old Apr 20, 2005 | 09:41 AM
Racermech's Avatar
if you hold the cluster in your hands, and flip it over it is green on the back. This is where everything hooks up. That is called the Green film, that is the part you have to switch.
Once again i am not 100% if this will make everything work. I am only realying info that i have read on HT in the past
Old Apr 20, 2005 | 10:19 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racermech &raquo;</TD></TR><TR><TD CLASS="quote">if you hold the cluster in your hands, and flip it over it is green on the back. This is where everything hooks up. That is called the Green film, that is the part you have to switch.
Once again i am not 100% if this will make everything work. I am only realying info that i have read on HT in the past</TD></TR></TABLE>
its all good. i appreciate the help. BUMP for help with the door panel wiring
Old Apr 21, 2005 | 10:34 AM
Default Re: ***Genereal Integra questions*** (japspecnegro)
bump for power door set up
jdmyelloweg
Mar 5, 2009 01:00 PM
germanegturbo
Dec 17, 2007 11:30 AM
SiRTifiedacc
Aug 7, 2006 02:47 PM
enphotography
Dec 29, 2005 06:37 PM
ITR0952
Oct 1, 2004 01:27 AM
