D16 Speedi-Sleeve
Searched and found nothing. I have a rear engine seal leak on my D16, and a new seal didn't do the trick, so I need a speedi-sleeve since the end is probably scarred and causing the leak. Anyone know where I can get one? If not, I could use the dimensions of the crankshaft end so I know which size to get and probably order it directly from Chicago Rawhide. Thnx.
