fan question
Old Apr 19, 2005 | 10:53 PM
95civickid's Avatar
Default fan question
my boi has a 91 civic dx hatch he needs to rerun the fan wire because the previous owner had the fan hooked up to were it is always on. he wants to rerun it so it works normally (when the motor gets hot).
Old Apr 19, 2005 | 10:56 PM
RCautoworks's Avatar
Default Re: fan question (95civickid)
On the back of the engine there is a 2 prong sensor, looks like green goo around it. Just run the 2 wires to that.
Old Apr 19, 2005 | 11:00 PM
95civickid's Avatar
Default Re: fan question (90blackcrx)
is it the same for the b16a? can you give a little better description of where it is?
Old Apr 19, 2005 | 11:01 PM
Yes same for almost all Honda engines, back of the block, just left of the oil filter. Mapquest it
Old Apr 19, 2005 | 11:05 PM
95civickid's Avatar
its a metal plug that plugs into the plastic?
Old Apr 19, 2005 | 11:08 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95civickid &raquo;</TD></TR><TR><TD CLASS="quote">its a metal plug that plugs into the plastic? </TD></TR></TABLE>
Honestly crawl under the car and look. You can't miss the 2 pronge green slim plug
Old Apr 19, 2005 | 11:10 PM
95civickid's Avatar
thanks will do tommorrow appreciate
Old Apr 20, 2005 | 05:54 PM
95civickid's Avatar
bump
Old Apr 20, 2005 | 07:11 PM
b18cEF9's Avatar
same question, 90 hatchback, obd1 gsr, my block doesnt have that sensor on the back, where else could it be?
Old Apr 20, 2005 | 07:32 PM
Default Re: fan question (b18cEF9)
Check near the thermostat
Old Apr 20, 2005 | 08:07 PM
b18cEF9's Avatar
gotcha, found it ontop of the thermo
crappyshifting
Apr 1, 2012 12:23 PM
namewasdallas
Dec 11, 2009 07:19 PM
slvrlude
Sep 3, 2008 09:38 AM
Sirfallsalot243
Dec 22, 2006 08:37 PM
rusteds2k
Feb 11, 2004 10:11 AM
