215/50/16 on 43 offset wheel. Rub or no rub?
Old Apr 19, 2005 | 10:08 PM
jsk62's Avatar
Default 215/50/16 on 43 offset wheel. Rub or no rub?
search only brought up 45 profile question and most people said it would be fine. how about 50 profile? you guys think it would rub, or be ok? my car is lowered, but only slightly.
Old Apr 19, 2005 | 10:20 PM
Bbasso's Avatar
Default Re: 215/50/16 on 43 offset wheel. Rub or no rub? (jsk62)
I would think it would, but don't know where...
Why would you want that size anyway?
Old Apr 19, 2005 | 10:28 PM
ZygSpeed's Avatar
I don't see why it would rub, the 50 series will just have a slightly higher sidewall (not wider).
Old Apr 19, 2005 | 10:57 PM
jsk62's Avatar
Default Re: 215/50/16 on 43 offset wheel. Rub or no rub? (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">Why would you want that size anyway?</TD></TR></TABLE>
buying a set of used ce28n's that have that size already mounted on them. i'm wondering if i can drive them as is until i wear them out, or if i need to dismount and get new tires immediately.
wouldn't the slightly taller sidewall make it more prone to rub on the inner fender well when making turns? iono, anyone else have any experience?
Old Apr 20, 2005 | 05:14 AM
typer_801's Avatar
If it only rubs on the inner fender, you're fine. That only occurs at full lock which is at very slow speeds, is preventable, and doesn't cause any permanent damage to the tires or car other than removing a little undercoating.
yaryar
Jan 10, 2008 07:11 AM
bravo831
Honda Civic (2001 - 2005)
49
Oct 17, 2006 12:10 PM
darkside788
Jul 26, 2006 09:38 AM
FrostyDC4
Apr 2, 2005 11:03 AM
PotatoePAPA
Apr 19, 2003 02:06 AM
