gsr vss
Old Apr 19, 2005 | 07:20 PM
phantom grey eg's Avatar
Default gsr vss
my 94 gsr vss went bad and when i call the dealer to get a new vss, they sent me a 2 bolt vss, i need a 1 bolt vss and they say that is the only listing, somebody help?
Old Apr 19, 2005 | 07:26 PM
s2kdre's Avatar
Default Re: gsr vss (phantom grey eg)
the two bolts hold it to the tranny, and the one bolt holds the connector.
Old Apr 21, 2005 | 11:23 AM
NeoGSR's Avatar
Default Re: gsr vss (jdmhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">the two bolts hold it to the tranny, and the one bolt holds the connector.</TD></TR></TABLE>
isn't the VSS on the rear wheels somewhere?
Old Apr 21, 2005 | 01:05 PM
Freshazzburu's Avatar
Default Re: gsr vss (NeoGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NeoGSR &raquo;</TD></TR><TR><TD CLASS="quote">isn't the VSS on the rear wheels somewhere?</TD></TR></TABLE>
On a B series, the VSS is on the tranny by the final drive.
Old Apr 21, 2005 | 01:21 PM
Default Re: gsr vss (Freshazzburu)
only one bolt holding it to the tranny and it canniot be seperated from the connector, it looks like a 99-00 si vss
Old Apr 21, 2005 | 01:22 PM
That's what i was thinking...lucky bastard...got a b16 tranny!!!! that's what i'm thinking i'm gonna change to when my tranny goes out
Old Apr 21, 2005 | 01:24 PM
looks like a 99-00 si vss but its not, the gear on my vss is about an 1/8 inch longer than 99-00 si vss
Old Apr 21, 2005 | 01:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phantom grey eg &raquo;</TD></TR><TR><TD CLASS="quote">looks like a 99-00 si vss but its not, the gear on my vss is about an 1/8 inch longer than 99-00 si vss</TD></TR></TABLE>
Hmmm...that's strange...every GSR tranny i've seen had the same 2 bolt VSS
Old Apr 21, 2005 | 01:41 PM
yup same here, all integra trannys are 2 bolt i believe, im thinking it could be an older jdm b16 out of like a sir2 or del sol dohc vtec
possibly the 99-00 si vss will work, i guess ill try that
Old Apr 21, 2005 | 01:46 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">=possibly the 99-00 si vss will work, i guess ill try that</TD></TR></TABLE>
good luck
Old Apr 21, 2005 | 01:49 PM
NeoGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Freshazzburu &raquo;</TD></TR><TR><TD CLASS="quote">
On a B series, the VSS is on the tranny by the final drive.</TD></TR></TABLE>
k, thanks
Old Apr 21, 2005 | 01:55 PM
if the 99-00 si vss doesnt work, i guess im **** outta luck
Old Apr 21, 2005 | 02:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phantom grey eg &raquo;</TD></TR><TR><TD CLASS="quote">if the 99-00 si vss doesnt work, i guess im **** outta luck</TD></TR></TABLE>
or you can always hook up a hamster in a wheel and gear it to the VSS so it can spin it as u drive...haha
Old Apr 24, 2005 | 11:37 AM
SOHKis's Avatar
do you still have the gsr vss? my friend is in need of one
Old Apr 25, 2005 | 02:07 PM
Default Re: (SOHKeg)
if the gsr vss was still good than i wouldnt have started this thread
Old Apr 26, 2005 | 07:56 AM
SOHKis's Avatar
Default Re: (phantom grey eg)
ok, i thought you might still have "the one from the dealer". but i guess you either returned it, or it was bad also.
Old Apr 26, 2005 | 04:58 PM
oh sry, yes i returned it, didnt mean to sound like an *******, thought you were talking about the one that was bad
Old Apr 26, 2005 | 07:46 PM
SOHKis's Avatar
haha... it's cool, how much do those things run from the dealer?
Old Apr 27, 2005 | 04:39 PM
i payed $180
Old Apr 27, 2005 | 04:56 PM
Spids5's Avatar
Don't judge or question
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phantom grey eg &raquo;</TD></TR><TR><TD CLASS="quote">only one bolt holding it to the tranny and it canniot be seperated from the connector, it looks like a 99-00 si vss</TD></TR></TABLE>
Its not a 99-00 si vss, I replaced mine on my old si and it had only one bolt.
Old Apr 27, 2005 | 04:57 PM
Spids5's Avatar
Yes it will.
Old Apr 27, 2005 | 06:00 PM
jaysonx's Avatar
Not that I am saying you are crazy, but just a suggestion. I thought that my VSS stopped working but it turned out being that all my grounds needed replacing. I lived at the beach at the time so everything had become a corodded mess.
Old Apr 27, 2005 | 06:02 PM
jaysonx's Avatar
BTW: this VSS came off of my 1994 LS tranny:
if I remember correctly, I replaced it with a 2 bolt VSS but only screwed in one bolt.
Old Apr 27, 2005 | 06:12 PM
Default Re: gsr vss (spids5)
so an 99-00 si vss will wok even thought the gear is smaller?
Old Apr 27, 2005 | 06:26 PM
Spids5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phantom grey eg &raquo;</TD></TR><TR><TD CLASS="quote">so an 99-00 si vss will wok even thought the gear is smaller?</TD></TR></TABLE>
I believe the gear is the same. I have a gsr, si and ctr gear and they all look the same. If it isn't though just swap them. All you have to do is pull out the pin, then swap them and then put the pin back in.
