JDM 4.7 FD and B16 Gears
Old Jan 30, 2002 | 06:01 PM
Big Teggie's Avatar
Default JDM 4.7 FD and B16 Gears
Hey guys, i have a gsr tranny right now and im gonna be rebuilding my motor for jun3's and want to shorten my gearing up. My car is a daily driver but i mostly drag race with it. I was thinking of just putting b16 2nd and 3rd gears in my gsr trans along with a jdm 4.7 final drive. Will this be a good setup for jun 3's and 9k shifts? Will i be shifting into 5th in the 1/4mile? I want it to be short but not too short. Also does anyone knwo what it would cost to get the work done? Thanks
Old Jan 31, 2002 | 12:10 PM
Big Teggie's Avatar
Default Re: JDM 4.7 FD and B16 Gears (Big Teggie)
Anyone have any opinions on this?
Old Jan 31, 2002 | 03:14 PM
salbaje's Avatar
if you were local i can do it for you. it will probably run you about 6-800 worth for the parts and labor
Old Jan 31, 2002 | 06:43 PM
Big Teggie's Avatar
Default Re: JDM 4.7 FD and B16 Gears (salbaje)
I need to find someone local who knows what they are doin. Im really serious about doin this to my trans.
Old Jan 31, 2002 | 09:33 PM
Katman's Avatar
Do it.
It's one of the best 'bang fo yo buck' upgrades out there besides a cam upgrade. The gearing combo your choosing will work great too. you just need to find somone to slap it all togetha for ya, for a decent price.
Old Feb 1, 2002 | 06:45 AM
Big Teggie's Avatar
Default Re: JDM 4.7 FD and B16 Gears (Katman)
Thanks Katman, atleast someone replyed, i need to find someone in nj to do the work. The parts are dececntly cheap, its just the labor that costs alot. I wont be shifting into 5th with this setup? peace
Old Feb 2, 2002 | 10:14 AM
Katman's Avatar
Thanks Katman...... I wont be shifting into 5th with this setup? peace
your welcome.
I hate seeing replies that don't answer or even remotely help out the postee.
You'll be shifting into 5th on the freeway.
Old Feb 2, 2002 | 04:16 PM
AE86's Avatar
You will be probably revving up 4th by the end of 1/4 mile. Ideally for a drag car you want to be as close as possible to the rev limit of your final gear so your setup is a great improvement. Besides if you run into any problems just get a bigger tire. I would start off with a 22" slick and go from there. Oh Jun3's are great cams too...
Question: what type of B16 trans did you pull the gears from? (hydro or Cable?) If hydro why not just swap out LSD and put 4.7 in the B16 Trans. Much easier to do.
Old Feb 2, 2002 | 04:34 PM
spankaveli's Avatar
Default Re: JDM 4.7 FD and B16 Gears (AE86)
probably to keep the gsr 1st, 4th and 5th
Old Feb 2, 2002 | 05:37 PM
AE86's Avatar
Default Re: JDM 4.7 FD and B16 Gears (spankaveli)
well you would be better off with the B16 gearing.
Old Feb 2, 2002 | 05:39 PM
spankaveli's Avatar
personally i'd go ITR with an LS 5th gear, but thats me.
Old Feb 2, 2002 | 06:53 PM
1 2 NV's Avatar
ITR is the same gearing as B16. as long as its USDM i mean.
Old Feb 2, 2002 | 11:06 PM
spankaveli's Avatar
Default Re: JDM 4.7 FD and B16 Gears (hondaatwsu)
i know....maybe i shoulda said b16 with itr lsd and ls 5th. either way, same results. its probably cheaper to get an ITR tranny than to get a b16 tranny then add an itr lsd
Old Feb 3, 2002 | 09:17 AM
AE86's Avatar
itr lsd's break. if your going to open up the box you might as well either weld up the stock lsd(cheap way out) or get a kaaz lsd. Also if your drag racing this car i don't see why you would want a ls 5th gear. Keep them all close thats the best combo. If your making alot of HP and are revving out just get a taller tire.
rrace002
17
Oct 28, 2012 12:21 AM
2000HondaEm1
Aug 7, 2009 04:39 AM
postman
Dec 24, 2005 06:53 PM
GSRCRXsi
May 20, 2005 08:00 PM
GSRCRXsi
