F20B Accord Type-R Swap Completed
Old Apr 19, 2005 | 05:58 PM
jdmaddiction's Avatar
Default F20B Accord Type-R Swap Completed ****Some pics are up not all****
We just got it done over the weekend in time for a local car show.
in 2 weeks time we did the swap and also got the car ready for and painted.
Pics will be up in the morn:
As always here is a little rundown of what went on.
We started with a 1994 Teg and were trying to figure out what swap to do..........and the idea came up of the F20b engine because it hasnt really been done, while doing a little research on what was needed.........nothing was comming up all that well we decided to just jump into it.
MOUNTS
We used our choice of H22 mount kit into teg.
-we had to get a motor mount bracket (bolts to engine) from an h22. other than that it dropped in.......
PS/AC/ALT
- We opted not to have PS because we wanted to keep the factory look of the F20
* but if wanted the newer Lude pump-brackets would work
- custom fuel line
-alternator was used from F20 and we just did a little repinning
-AC compressor was used from F20 with custom fabed lines, and we had them crimped together by a hydro shop *******yes we do have AC******
DRIVE
Axles we used the older accord mid-shaft and 93 integra ABS axles
WIRING
-used the facory integra harness with mods
-extensions were made and converted the obd2 sensors into obd1 sensors
- no resistor box was required for injectors
- eliminated EGR and other sensors and used one of our chipped P28 h22 progs
- had to wire in the 3 wire IAC
- rewired injector harness to OBD2
-Prelude OBD1 dist was used instead of the F20 to make it easier
Draw backs from swap we learned:
- the injectors are alot diff than the normal honda
-there are some parts not in the US for the motor.
-if the IAC goes bad, good luck on finding anotherone...............
-alot more parts are required over doing a H22swap
-no info on the engine around
-wire colors of the F20 are diff than any other honda, so there is alot of testing that is needed to be done
++ about the swap:
-not a popular swap and really hasnt been done
-we did it
-high reving motor
-feels great
-has a diff sound other than any other honda
-attracts attention
*******there were a few things left out that will be mentioned at a later time after the pics are posted ********
Modified by jdmaddiction at 11:15 AM 4/26/2005
Old Apr 19, 2005 | 07:48 PM
RidinStock's Avatar
Default Re: F20B Accord Type-R Swap Completed (ps2wiz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ps2wiz &raquo;</TD></TR><TR><TD CLASS="quote">Cant wait for pics...</TD></TR></TABLE>
Same here, did you do pics as you progressed or only at completion?
Old Apr 20, 2005 | 08:49 AM
Danziver's Avatar
Default Re: F20B Accord Type-R Swap Completed (jdmaddiction)
Sounds cool, post up some pix asap.
Old Apr 20, 2005 | 10:01 AM
King Tut33's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmaddiction &raquo;</TD></TR><TR><TD CLASS="quote">Pics will be up in the morn</TD></TR></TABLE>
It appears to be the afternoon now. Pics or BAN.
Old Apr 20, 2005 | 10:10 AM
dmxsoulja3's Avatar
Default Re: F20B Accord Type-R Swap Completed (King Tut33)
yeah sucka, we wanna see pics.
Old Apr 26, 2005 | 10:14 AM
sorry for not getting them up sooner but here are some
Old Apr 26, 2005 | 10:24 AM
CNSK's Avatar
Default Re: F20B Accord Type-R Swap Completed ****Some pics are up not all**** (jdmaddiction)
sick......
Old Apr 26, 2005 | 10:26 AM
B2FiNiTY's Avatar
Default Re: F20B Accord Type-R Swap Completed ****Some pics are up not all**** (CNSK)
What makes it so different? As far as feel and sound?
Old Apr 26, 2005 | 10:56 AM
tegsallgood's Avatar
Default Re: F20B Accord Type-R Swap Completed ****Some pics are up not all**** (B2FiNiTY)
has it been dyno'd? weighed? run at the track? anything at all in terms of performance?
Old Apr 26, 2005 | 11:32 AM
gracedIntegra's Avatar
werd! that is awsome.
Old Apr 26, 2005 | 12:49 PM
RidinStock's Avatar
Default Re: (gracedIntegra)
wow!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">What makes it so different? As far as feel and sound? </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegsallgood &raquo;</TD></TR><TR><TD CLASS="quote">has it been dyno'd? weighed? run at the track? anything at all in terms of performance?</TD></TR></TABLE>
Old Apr 26, 2005 | 01:03 PM
JDM_Risa's Avatar
good job looks very clean.....shud pull like a ************
Old Apr 26, 2005 | 01:42 PM
IntegraGuy16's Avatar
Default Re: F20B Accord Type-R Swap Completed ****Some pics are up not all**** (GunMETAL_TEgRa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gracedIntegra &raquo;</TD></TR><TR><TD CLASS="quote">werd! that is awsome. </TD></TR></TABLE>
Old Apr 26, 2005 | 01:50 PM
GSR92's Avatar
nicely done
Old Apr 27, 2005 | 06:57 AM
the sound has a diff tone than H-series and B-series........
and the feel is not really diff, it feels nice though a nice TQ'y motor that you can bring up to 9k rpm is a little diff than other swaps
Old Apr 27, 2005 | 07:25 AM
dFreezy's Avatar
nice, i haven't heard of this type of swap before
Old Apr 27, 2005 | 07:36 AM
fastlifemotorsports's Avatar
Nicley done
Old Apr 27, 2005 | 07:39 AM
Mattyg2's Avatar
get some sound clips
Old Apr 27, 2005 | 07:45 AM
gaydm.accord's Avatar
displacement is better, higher comp, and like maybe shy off couple =tq from the h22.
oh and its non frm sleeving.
i really wanted to swap this motor in but i opted for the h22. gj guys. i recently just saw another teg on ht with the same swap in it. and my buddies also working on this swap as we speak.
Old Apr 27, 2005 | 09:32 AM
ATS*ALLDAY's Avatar
ATS builds MiracleWhips..
thats crazy!!!!!
Old Apr 27, 2005 | 11:28 AM
BaGGed HoNDa's Avatar
You did a really nice job on the swap, hurry up and post a sound clip though. Incredible!
Old Apr 27, 2005 | 11:39 AM
ecks_fourttwo's Avatar
Default Re: (BaGGed HoNDa)
sweet...props
Old May 2, 2005 | 12:38 PM
machine4321's Avatar
i just got mine in my 95 accord ..waitting for some parts for the ITB's and then its fdoen till i get money ...
cant wait to rip on it
Old May 2, 2005 | 12:45 PM
TheGSRGuy's Avatar
Default Re: (machine4321)
Props to you, that's really unique.
Any sound clips?
Old May 2, 2005 | 12:58 PM
HONDA RR's Avatar
Default Re: (TheGSRGuy)
Damn thats pretty crazy i have never seen such a swap. Great job !
