Very embarassing
i ran a 17.1 at the track in salt lake in my 98 gsr last week. i have a dc header no PS, cam gears nology wires denso iridium plugs a short ram intake high flow cat and a catback
What the hell!! i do have a 100 grand in milage do i need to adjust valve lash and stuff like that? why such a slow time? i think it might be my 17" motegi MR7's do they have that much effect?
Help!!
Help!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elserg80 »</TD></TR><TR><TD CLASS="quote">60 foot was 4.3, R/T was .333, 1/8 was about 11, speed was about 81</TD></TR></TABLE>
Wow, that's your problem. You want your 60ft to be in the 2.x at least... How do you launch? Did you just dump the clutch? Did you have extreme wheel hop and vibration? That's where you lost a lot of time...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra95gsr »</TD></TR><TR><TD CLASS="quote">holy, a 4.3 60ft.. thats probably a problem are u getting out of the car and pushing it the first 60 feet.. lol kidding, but that isnt good.. most likely its just driver</TD></TR></TABLE>
lmao! He's not kidding! I've never seen a 0-60 that slow before.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tub_sephiroth »</TD></TR><TR><TD CLASS="quote">
lmao! He's not kidding! I've never seen a 0-60 that slow before.</TD></TR></TABLE>
****, you should have seen my first time slip.
I still need practicing too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DavidT or VajT »</TD></TR><TR><TD CLASS="quote">dude...81 mph is HELLA slow...your time is correct if you only trapped that high...</TD></TR></TABLE>
lol who cares about the trap when he's got a 60ft time like that. do some searches on launching so you can cut down on that and your times will drop considerably.
are your tires bald? maybe you were spinning the whole time?? not trying to flame at all but I ran a 2.9 60ft in my stock mazda 323. I dont know, go somwhere desolate and practice your launch. Also an 11 second 1/8th is very slow for a gsr Ive seen a LS with those same mods run a 9.9. Maybe your track is dirty we have that problem here in jacksonville, I dont know it could be hundreds of reasons. give us a full rundown on what you did. What RPM's did launch at, what RPM's did you shift at? (its a GSR so you should have been shifting in the 7thousand range I would guess)
when the staging lights came on did you rev up to at least 2k rpm?
when the last yellow came on did you go?reation time will make the car move when it is green.
Max each gears rpm out before shifting. You have power in each gear till 8k rpm
My first time at the track I pulled a 15.2
I have yet to be able to get that again. My trap speed was 92mph I believe.
Your launch needs the most work by looking at your #'s.
Rev up get a little spin of the tire, feather(work) the clutch till the tires grip.
This is why you hear people complaining about tire/wheel hop. When spinning the tires on an agressive launch, the cars weight is transfered to the rear(physics) and the front end becomes light. You will have to rev the engine up to get ample power to get an agressive start and use the clutch so the rpms don't drop since our integra's don't have very much toque to pull them outta the hole.
Before I goto the track I:
-oil change
-clean cai filter(change filter on non-aftermarket intakes)
-valve adjustment (.008 exhaust,.007 intake)
-tank of fule injector cleaner when summer starts(get this at local parts store and pour it in the gas tank)
-check tires for tread.
Overall make sure routine maintenance has been done:
fuel filter
spark plugs
distributor cap
rotor
plug wires
-oil change
fuel filter
spark plugs
distributor cap
rotor
plug wires
Getting a 4.3 60ft is pretty bad...i mean either you REALLY babied it out of the hole or you just did a huge burnout. I mean i've had what felt like some bad launches but they were still like 2.6-2.9. My best run was a 2.4 60 and i went 14.7 at 95 with the mods in my sig. I guess you just need to practice launching and shifting faster. Usually the best way to launch is to SLIP the clutch from like 3-4k rpms. Usually it will result in maybe a little bit of wheelspin but not too much, and the rev's shouldn't drop below 4-5k once you get going. Then its just shifting, watch the tach and when it gets to redline or a bit after pound it into the next gear...thats it
i ran almost the same time my first run in my gsr
i am more used to launching w/ slicks... i had some shitty *** stret tires and launched at about 3500 rpms dropped the clutch, I pretty much spun the wheels until third gear.... race tracks are harder to launch with street tires... so i would practice in that area, but that trap speed does seem pretty low too
**** take it easy i may have been wrong on my times i dont have my time cards. my 60 foot may have been a 3.3 i have no clue about the rest though i did see a **** load of wheel hop and i was actually beating the 5.0 next to me and he just took of after the 1/8 marker. i was getting up to aout 90mph at the 1/4m with the stock rims on the street.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elserg80 »</TD></TR><TR><TD CLASS="quote">**** take it easy i may have been wrong on my times i dont have my time cards. my 60 foot may have been a 3.3 i have no clue about the rest though i did see a **** load of wheel hop and i was actually beating the 5.0 next to me and he just took of after the 1/8 marker. i was getting up to aout 90mph at the 1/4m with the stock rims on the street. </TD></TR></TABLE>
Well if you want help we need to know the specifics. Don't bitch at us for you pulling numbers out of your head.
I vote for the rims
They may not be the only reason.. but i think they definetly have a factor in it - tirerack.com did a lot of testing on how weight affects accel and speed, it could also be your suspension not giving you enough traction, messing up your launch.. things like that.
As for the driving... like the other guys said practice shifting quicker.. one of my first mods was a short shifter, that helped me to be able to find the gears a lot quicker (when i first got my teg i had a nasty habbit of going from 1st to 4th lol) And don't forget your driving a rev-happy, hi-rpm, Vtec, Honda - don't be afraid to take it up there (just avoid bouncing the rev limiter) good luck
oh - and remember light-weight wheels are considered light-weight when they are a pound or more lighter than the diameter
i am shifting at 8 or about 7800 where is the rev limiter though. i actualy have a short shifter and i shift pretty quick what about valve adjustments ive put 20,000 on the car and i havent done one yet i dont know if thats ever been done but my belt has been replaced though and how about my cam gears what should i set them to.
