will a 4-2-1 dc header for a B18C fit a B18a?
Old Apr 19, 2005 | 12:55 PM
Honduh Chicken's Avatar
I fry gay turkeys
Default will a 4-2-1 dc header for a B18C fit a B18a?
The header is for a 94-99GSR and I need to know if it will fit a 91LS?
graci-***.
Old Apr 19, 2005 | 01:39 PM
4U2NV's Avatar
Default Re: will a 4-2-1 dc header for a B18C fit a B18a? (Honduh Chicken)
Well yes and no... Yes it will bolt to the head, and the manifold flange will bolt up, but the length will almost surely be wrong... If you got it, you may have to have the exhaust extended to push the cat up to the header...
So as far as it being a direct bolt-on application, no...
Old Apr 19, 2005 | 02:45 PM
purplegsr's Avatar
Default Re: will a 4-2-1 dc header for a B18C fit a B18a? (4U2NV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4U2NV &raquo;</TD></TR><TR><TD CLASS="quote">Well yes and no... Yes it will bolt to the head, and the manifold flange will bolt up, but the length will almost surely be wrong... If you got it, you may have to have the exhaust extended to push the cat up to the header...
So as far as it being a direct bolt-on application, no... </TD></TR></TABLE>
Yes, this is pretty much correct. The header will bolt to the head, but it should be too short and will not have an o2 bung. So, you will probably need to get a short little pipe with flanges on either side, and an o2 bung in the middle, in order to get the shorter 94-99 GSR header to mate with your 91 LS cat. In addition, the 90-91 Integra has the o2 on the left most runner of the header, rather than at the collector, like the 92-93, so you will need to extend the o2 wire as well.
Old Apr 19, 2005 | 07:51 PM
I fry gay turkeys
Default Re: will a 4-2-1 dc header for a B18C fit a B18a? (purplegsr (Exospeed))
Thanks guys. good info.
preludepower01
May 18, 2009 09:03 PM
lilo_goki
Jun 9, 2008 12:18 PM
JDM CTR EK
Feb 16, 2004 07:06 PM
shannon
Dec 26, 2003 06:55 AM
SantaCruz92Si
Jul 22, 2003 01:57 PM
