OEM Brakes
I just got back from Acura and picked up a set of OEM pads for my 00 GS-R.
I think i might have been given the wrong rear pads. According to acuraparts247.com it says:
Front = 45022-ST7-A02
Rear = 43022-ST7-A02
What acura gave me says:
Front = 45022-ST7-A02 OK
Rear = 43022-SR2-030 (Did they give me the wrong part?)
i would probably go by acuraparts247 since they use the actual acura manuals. call the dealership and confirm, the parts dept probably just gave you the wrong ones by accident.
Call the parts dept and ask.
Also, I'd suggest contacting cobalt friction next time you get ready to change pads. Andy's very, very helpful and will give you 10% discount if you say you're a member of HT.
I think 43022-SR2-030 is a Honda part #, did you get it at an Acura or Honda dealership parts dept?
Edit - those pads will fit the 94 Del Sol Si and Del Sol VTEC evidently, I never heard of anyone using them on 00 Integras, but it might work.
Just an FYI, I called various Acura dealerships and they said that part numbers get superceded all the time. Therefore, the part number I said above is the correct one and from my understanding will be the new one for the rear brake pads.
43022-SR2-030 now supercedes 43022-ST7-A02
those part #s are for the same parts. del Slo Si and VTEC and Civic DOHC VTECs have the same rear brakes as us 3G integras do, except Type-R, but i think those pads may also be the same size, just a 4mm larger piston and farther from the hub.
BrakeExpert
Honda Civic (2006 - 2015)
81
Mar 30, 2016 07:46 AM
BrakeExpert
Feb 9, 2013 01:29 PM
95GSRBOI
Sep 18, 2005 01:27 PM
