Which ECU / piggyback will raised an idle?
Old Jan 30, 2002 | 04:27 PM
teg92's Avatar
Default Which ECU / piggyback will raised an idle?
Just wondering if a S-AFC or what stage hondata can modify your idle. If both can, can an aftermarket drop in chip achieve the same thing (i.e. is idle rpm an electronically adjustable parameter?)
Also just wondering if hondata would be a waste of time on a non-vtec or not. I find their website a little unclear, it seems only stage 4 allows you to adjust your timing and fuel curves, is this right? TIA
Old Jan 30, 2002 | 04:31 PM
JG Luder's Avatar
Default Re: Which ECU / piggyback will raised an idle? (teg92)
to my knowledge, you don't HAVE to ues your ECU or a piggy back to raise idle. What car are we speaking of here?
Old Jan 30, 2002 | 04:54 PM
teg92's Avatar
Default Re: Which ECU / piggyback will raised an idle? (JG Luder)
92 integra. Can the idle adjustment screw actually raise it 300-400rpm?
Old Jan 30, 2002 | 08:06 PM
tinkerbell's Avatar
anthing that adds controled amounts of air at idle will raise it EG pull a manifold hose...
the throttle screw could help 300-400 rpm i think...
it does on a B16A.
t..
Old Jan 30, 2002 | 09:26 PM
teg92's Avatar
Default Re: Which ECU / piggyback will raised an idle? (tinkerbell)
Great once I get my head installed with the 404's I want to be able to bring my idle up to 1000 or 1100rpm...
Old Jan 30, 2002 | 09:28 PM
tinkerbell's Avatar
...possibly...
Old Jan 30, 2002 | 10:50 PM
976's Avatar
976
New User
Maybe this isn't the answer you're looking for, but why not adjust your idle yourself? Screw driver to idle screw on throttle body...
jdm.ejone
Jun 15, 2008 04:50 PM
GruvyTune
Aug 29, 2002 10:27 PM
Black R
May 14, 2002 11:59 AM
teg92
Jan 30, 2002 05:37 PM
