{FS}crx, b16, zex, and parts for those...
Old Apr 19, 2005 | 10:11 AM
caster troy si's Avatar
Default {FS}crx, b16, zex, and parts for those...
stock b16a intake manifold 2 holes in it, one in the flange, one on the coolant runners on the side.
b16a head, ported and polished with powdercoated(red) valve cover
stock b16 flywheel and pressure plate. stock crx springs w/ 50xxx miles on them.
parts to the head, timing cover, comp cams valvesprings and retainers, cam seal, O2 sensors
victor x b16 intake manifold, RC 440's, edelbrock pro-flo fuel rail, b&m fuel pressure regulator, autometer fuel pressure gauge
N1 crank pulley
more b16 parts, head gasket, valve cover gasket, distributor with msd cap, msd wires, intake
88 crx dx
battery box
13 in steelies and a couple 14 in
crx parts
internals to an LS that's differential ate itself
cable transmissions
all of the aftermarket parts are new.
parts not pictured:
the zex dry kit's bottle and remote bottle opener aren't pictured.
the motor will be sold as a longblock at minimum and has new timing belt and water pump.
the clutch, pressureplate, and flywheel from my b18a. good condition.
also a centerforce DFX clutch and zex flywheel brand new.
make offers on what ever you want.
Modified by caster troy si at 7:25 PM 4/19/2005
Old Apr 21, 2005 | 12:51 PM
Default Re: {FS}crx, b16, zex, and parts for those... (caster troy si)
bump
FW_EJ8
Northern California (Sales)
13
Sep 15, 2008 07:36 AM
EF_FEVER
Sep 6, 2008 05:42 PM
Ef8forlife
Appearance Build Threads
Jun 3, 2008 12:37 PM
type Gendy
May 6, 2005 09:19 PM
