Si/Hf .into Dx ?? (wiring harness)
Old Apr 19, 2005 | 09:45 AM
hedtrip's Avatar
Default Si/Hf .into Dx ?? (wiring harness)
i have a 88 Civic HB dx .. & i have replayced the intre wiring harness with a Si harness ..& a Hf Engine harness ..... Can i use all the same relays & sensors ,,& map sensor from the dx .or do i have to convert all that to ??? ....it trys to crank but just wont start..... would the hf harness on the si harness ....change anything ??
it's throwing code 20 6 & 9 ... that last 1 scars me ..lol
Old Apr 19, 2005 | 10:12 AM
CRX Toad's Avatar
Default Re: Si/Hf .into Dx ?? (hedtrip)
Yes the none of the harnesses are compatible. You would need to use a HF engine and underdash, Si engine and underdash, to make everything 100% compatible. You can switch some wires probably I just don't which ones
Old Apr 19, 2005 | 09:40 PM
hedtrip's Avatar
thanx .... do u know of any sites with instructions ..or a how to? to swich the wires around ?
Old Apr 20, 2005 | 01:10 AM
Rywire's Avatar
Default Re: (hedtrip)
Your best bet is to have the dx engine harness modified my me at http://www.rywire.com
Ryan
MR.johnson
Apr 21, 2008 04:34 AM
shackler
Mar 22, 2007 07:21 PM
FAST AS
10
Mar 23, 2004 12:17 AM
fwpguy
Feb 8, 2004 08:58 PM
DOHC_EF
Oct 12, 2003 05:56 PM
