Spoon Monoblock Calipers now available for DC2R
Old Apr 19, 2005 | 08:50 AM
Jim80y's Avatar
Default Spoon Monoblock Calipers now available for DC2R
http://www.spoon.jp/jp/product...e=301
Spoon now offers a bracket so you can use the monoblock caliper previously only available for the S2k and DC5. More importantly, the use of the monoblock caliper lets you use 300mm S2k/DC5 rotors which are 26mm thick, and you'll need at least 16" rims. Who wants to be first to try?
Old Apr 19, 2005 | 08:53 AM
{Powered by VIII}'s Avatar
Default Re: Spoon Monoblock Calipers now available for DC2R (Jim80y)
wats the difference between the monoblock and the regular calipers? im interested!!
Old Apr 19, 2005 | 08:55 AM
esponet's Avatar
Default Re: Spoon Monoblock Calipers now available for DC2R ({Powered by R})
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by {Powered by R} &raquo;</TD></TR><TR><TD CLASS="quote">wats the difference between the monoblock and the regular calipers? im interested!! </TD></TR></TABLE>
its made for bigger rotors. i have been thinking about this for a while.
spoon monoblock, then use mugen rotors.(the one used for the active gate system) it would be kinda best of both worlds.
Old Apr 19, 2005 | 09:04 AM
MattD@Stoptech's Avatar
Default Re: Spoon Monoblock Calipers now available for DC2R (esponet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esponet &raquo;</TD></TR><TR><TD CLASS="quote">
spoon monoblock, then use mugen rotors.(the one used for the active gate system) it would be kinda best of both worlds. </TD></TR></TABLE>
At that price point it would make a lot more sense to go with something that's been engineered to work together. Like a stoptech kit.
Old Apr 19, 2005 | 09:26 AM
Black R's Avatar
25 Year Member
.....too bad 16" tyre selection = t3h sUx!
Now if the monoblock's would fit under some crazy offset wiiide 15" wheelz.....
Old Apr 19, 2005 | 09:27 AM
Default Re: Spoon Monoblock Calipers now available for DC2R (Black R)
Why would you want to do that without upgrading the thermal capacity of the rotor?
Old Apr 19, 2005 | 09:30 AM
jdmvtec28's Avatar
Default Re: Spoon Monoblock Calipers now available for DC2R (El Pollo Diablo)
By going with a larger thicker rotor doesn't that in effect upgrade the thermal capacity of the rotor?
Old Apr 19, 2005 | 09:33 AM
Willard's Avatar
Default Re: Spoon Monoblock Calipers now available for DC2R (jdmvtec28)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmvtec28 &raquo;</TD></TR><TR><TD CLASS="quote">By going with a larger thicker rotor doesn't that in effect upgrade the thermal capacity of the rotor?</TD></TR></TABLE>
yes.
Old Apr 19, 2005 | 09:43 AM
Default Re: Spoon Monoblock Calipers now available for DC2R (Willard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">
yes. </TD></TR></TABLE>
by a couple percent, no?
Old Apr 19, 2005 | 09:48 AM
DC2IntegraTypeR's Avatar
Monocoque Caliper Forward (Left)
INTEGRA TYPE-R [DC2, DB8(98Spec)*] 45019-MBF-G00 \77,700 1Set
Monocoque Caliper Forward (Right)
INTEGRA TYPE-R [DC2, DB8(98Spec)*] 45018-MBF-G00 \77,700 1Set
$725.70 per caliper eh? Are these calipers designed to utilize stock-pad sized brake pads also?
Old Apr 19, 2005 | 09:51 AM
thk's Avatar
thk
Members Only
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">At that price point it would make a lot more sense to go with something that's been engineered to work together. Like a stoptech kit.</TD></TR></TABLE>
Yeah. If I had to go up on wheel size for a brake upgrade, I'd go Stoptech too.
Old Apr 19, 2005 | 09:52 AM
Black R's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">Why would you want to do that without upgrading the thermal capacity of the rotor?</TD></TR></TABLE>
.....so I could bling the **** out at all the car sh0wz, y0!
Old Apr 19, 2005 | 10:26 AM
bitzbp's Avatar
Already did it!!! Except its on my hatch. I used the s2k Spoon monoblocks with the Mugen rotors and it fits perfectly. Also by using the Mugen Active Gate rotors, you lose a little mass and hopefully gain some cooling and venting. Once I can get the rest of the car sorted out the car will be a track car. At the moment the manual rack is killing the car in the tight corners.
I've got pics in my camera ready to be uploaded for the haters
The calipers use the s2k pads and according to spoon the overall piston volume inside the calipers is either the same or smaller then the stock ITR caliper so there is no problem using the ITR master cylinder.
I'll admit this setup didn't really cost me a dime because its a friends parts, but there is no way I would ever spend that kind of cash especially when the stock ITR calipers/rotors, nice pads, and sticky tires are more then enough for a regular ITR let alone my 2200 pound hatchback.
Old Apr 19, 2005 | 10:29 AM
B2FiNiTY's Avatar
Default Re: Spoon Monoblock Calipers now available for DC2R (bitzbp)
lets see them pics
Old Apr 19, 2005 | 10:44 AM
cryptikman's Avatar
Default Re: Spoon Monoblock Calipers now available for DC2R (B2FiNiTY)
I demand pictures as soon as possible.
Old Apr 19, 2005 | 11:13 AM
Chris93Si's Avatar
Does anyone know the size of the pistons in the monoblocks? I think the twinblocks have one 38.x and a 42.x on each side. If I remember correctly the monoblocks weigh more than the twinblocks.
Old Apr 19, 2005 | 11:39 AM
bitzbp's Avatar
Default Re: Spoon Monoblock Calipers now available for DC2R (Chris93Si)
Ok I wasn't going to post any pics till more of the car was done, but here are a few. I will take better pics with the wheels off to show the Mugen Active Gate rotors. Current suspension is Spoon N1 and is stiff as *****.
Old Apr 19, 2005 | 11:45 AM
Bbasso's Avatar
hrmmm....
Old Apr 19, 2005 | 11:47 AM
Chris N's Avatar
Default Re: (RisforTypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RisforTypeR &raquo;</TD></TR><TR><TD CLASS="quote">
$725.70 per caliper eh? </TD></TR></TABLE>
Rather have.... nevermind. Pollo already said it.
Old Apr 19, 2005 | 12:02 PM
IGGY's Avatar
Dude! Where did you get those tires! I have been trying to get some bad! OMG
Old Apr 19, 2005 | 12:10 PM
bitzbp's Avatar
Default Re: (IGGY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IGGY &raquo;</TD></TR><TR><TD CLASS="quote">Dude! Where did you get those tires! I have been trying to get some bad! OMG</TD></TR></TABLE>
Straight from japan. My buddy lives about a block away from Spoon and he goes to japan every few months, so he bought a set of used volks and those tires brand new and brought them back on the plane with him. The tires were more expesive then the rims from what he tells me. He is also the one that owns the suspension and brakes.
Old Apr 19, 2005 | 12:14 PM
ebelp's Avatar
Default Re: (bitzbp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bitzbp &raquo;</TD></TR><TR><TD CLASS="quote">Straight from japan. My buddy lives about a block away from Spoon and he goes to japan every few months, so he bought a set of used volks and those tires brand new and brought them back on the plane with him. The tires were more expesive then the rims from what he tells me. He is also the one that owns the suspension and brakes.</TD></TR></TABLE>
That's one hell of a friend.
Old Apr 19, 2005 | 12:17 PM
cmdr430's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">.....too bad 16" tyre selection = t3h sUx!
Now if the monoblock's would fit under some crazy offset wiiide 15" wheelz..... </TD></TR></TABLE>
they should fit under these...... and they are in ATL.......
2. Real Racing R2: 15x7, +39mm, forged, ~10.5 lbs - $1250 with 205/50/15 Falken Azenis
*#2 part is ITR specific as it clears ITR spec Spoon Calipers without spacers.
No mod needed to make it fit over Spoonies & no need to roll the fenders even with 2" drop.
Perfect for track wheels.
pic of the wheels: http://www.globalautoshop.com/wheels/starform.htm
https://honda-tech.com/zerothread?id=1211796
Old Apr 19, 2005 | 12:19 PM
IGGY's Avatar
So how much? I want them but I'm afraid to know exactly how much they really are.
Will you be able to get another set?
Old Apr 19, 2005 | 12:50 PM
Kengs's Avatar
Nice tires
