pedal assembly sparking!?!
Old Apr 18, 2005 | 10:29 PM
rexizbest's Avatar
Default pedal assembly sparking!?!
Alright, ive been having an electrical problem for the last month now. When i hit my brakes my lights dim and my cd player shuts off momentarily. Well, tonight i was messing with my throttle cable and while i was down there i noticed that when i hit the brakes i get a spark off of the pedal assembly! thats when everything cuts out. Anyone ever have this happen before or know how i can fix it?? thanks in advance.
Old Apr 18, 2005 | 11:24 PM
NikoZai's Avatar
Default Re: pedal assembly sparking!?! (rexizbest)
HAHAHAHAHAHAHAHA
So are your brake lights grounding at the pedal to create the circuit?
There is something called the "BRAKE LIGHT SWITCH" at the pedal assembly.
No wiring should be touching your pedal what-so-ever. Your pedal should contain no electric charge.
http://www.norcalcrx.org/library/
download the CRX WORKSHOP MANUAL
Read page 338 and 610 then get back to us.
Page 610 shows us that there is a 12v+ current running into the "Brake Light Switch" at the pedal.
There should be rubber insulation, if there is not, that 12V is likely running through the metal of the switch into the pedal itself.
Problem solved
Old Apr 19, 2005 | 07:41 AM
rexizbest's Avatar
Default Re: pedal assembly sparking!?! (NikoZai)
hah, yup that was it. Thanks a lot!!
gsxr-t-bag600
Dec 27, 2011 09:51 PM
zsiya
Aug 17, 2011 10:41 PM
93grayeg
19
Sep 8, 2009 07:30 PM
Drokit22
Jan 3, 2009 02:31 PM
Agent Daimon
11
Jul 19, 2002 08:39 PM
