JDM ITR gauge cluster - how many plugs?
the plugs that i have on my car are 2 blue plugs, 13pin and 15pin connector and a 5pin connector, yellow.
i just got a jdm itr cluster (dont know what yr) but i plugged everything in and the rpm doesnt work. srs,abs light stays on. so which cluster should i get?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marko_think »</TD></TR><TR><TD CLASS="quote">what happened to all the jdm rhd itr people?</TD></TR></TABLE>
I guess they're in Japan?
JDM 96 spec had 2 plugs
JDM 98 Spec had 3 plugs, the third (yellow) is for SRS (airbags), which were not available on the ITR till the 98 spec came about.
my car only has the 2 plug because i converted using a 96 spec car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RPRacing »</TD></TR><TR><TD CLASS="quote">JDM 96 spec had 2 plugs
my car only has the 2 plug because i converted using a 96 spec car</TD></TR></TABLE>
thanks for the info. but are you sure 96 spec never came with srs? because i have the yellow plug.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marko_think »</TD></TR><TR><TD CLASS="quote">thanks for the info. but are you sure 96 spec never came with srs? because i have the yellow plug.</TD></TR></TABLE>
Sounds like he knows what he's talking about to me.
but it was available as an option, though I have never seen an example where they were fitted.
