Physical diffs between 88-91 and 92-95 SOHC header
Old Jan 30, 2002 | 03:08 PM
bigrob119's Avatar
Default Physical diffs between 88-91 and 92-95 SOHC header
What would prevent me from using a later model SOHC header on the earlier SOHC engines?
Old Jan 30, 2002 | 03:26 PM
bigrob119's Avatar
Default Re: Physical diffs between 88-91 and 92-95 SOHC header (bigrob119)
Nah, I meant aftermarket, and the only thing I was really concerned with was the bolt pattern on the block vs the header...thanks for the info.
Old Jan 30, 2002 | 05:10 PM
markedOO1's Avatar
...it bolts up fine. no probs....only dif is the lower bracket, it doesnt line up but its not really necessary....
Old Jan 31, 2002 | 02:34 PM
Aphrodavid's Avatar
Default Re: Physical diffs between 88-91 and 92-95 SOHC header (marked001)
the O2 sensor on the 92-95 header is further down than the 88-91.
Old Feb 1, 2002 | 12:36 PM
therealciviczc's Avatar
Default Re: Physical diffs between 88-91 and 92-95 SOHC header (DX-R)
I think the 92 hangs just slightly lower, but not enough to make a big difference. I may be wrong, but I've used them twice, and it appeared that way to me.
Old Feb 1, 2002 | 12:38 PM
markedOO1's Avatar
Default Re: Physical diffs between 88-91 and 92-95 SOHC header (therealciviczc)
yeah, they do hang a bit lower b/c the sohc vtec block is a little lower...
Old Feb 1, 2002 | 12:53 PM
TypeR0207's Avatar
The O2 sensor is close to the cat, you will have to add about 2'-3' of wire to the single wire O2 on the stock one.
Works fine ...... that is what I have (got it for $25 ....).
Old Feb 1, 2002 | 07:00 PM
89civicdx's Avatar
Default Re: Physical diffs between 88-91 and 92-95 SOHC header (TypeR0207)
my old lightspeed header had the same part # for 88-95.
SwtnShyBoi29
10
Jul 22, 2006 04:40 AM
.Ryan
Jul 28, 2004 08:54 PM
STREETWERKZ
Apr 28, 2004 09:20 PM
hondaciv3
Aug 9, 2003 04:35 PM
