Apexi Power FC
Old Apr 18, 2005 | 07:55 PM
RicTRD's Avatar
Default Apexi Power FC
Is anyone using the Apexi Power FC in ITR. I'm considering getting one but I want to know if this unit has as default a racing program ROM for the DC2 ITR when you order it or it comes with a normal ITR ROM like an OEM ecu . Or do I have to tune it with a dyno, the problem here in Guatemala is that we don't have dynos.
Old Apr 18, 2005 | 07:58 PM
BlueR's Avatar
Default Re: Apexi Power FC (RicTRD)
if you buy it from a Power Excel Dealer such as http://www.p1auto.com , they can load any program you want
Old Apr 18, 2005 | 08:05 PM
Cone's Avatar
Default Re: Apexi Power FC (BlueR)
yes, it comes with a "tuned" base ITR map. They reccomend tuning it professionally in the manual, but who doesn't say that? I'm running it in my car. Ran it in my last near stock ITR too. Great power gain with bolt ons, gas milage was better, ran it for probably 10K miles, but never had a chance to dyno it. Great ECU, though. My buddy Pete made 180whp/126wtq on his ITR tuned with the Power FC using J's intake, Spoon header, test pipe, stock exhaust. Pretty respectable I'd say. Aside from the AEM EMS, its the only ECU I'd ever use.
Old Apr 18, 2005 | 08:07 PM
BlueR's Avatar
Default Re: Apexi Power FC (Stealth 95 GS-R)
for a NA car, its the best you can get
i love mine
Old Apr 18, 2005 | 08:08 PM
Kengs's Avatar
You should get a Datalogit so you (or your tuner) can access all the tuning features of the PowerFC:
http://www.fc-datalogit.co.nz/
Old Apr 18, 2005 | 08:10 PM
BlueR's Avatar
Default Re: Apexi Power FC (Kengs the "OG" JDM Junkie)
agreed, the dataloggit is much easier to use that the handheld commander
Old Apr 18, 2005 | 08:20 PM
CPR's Avatar
CPR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">agreed, the dataloggit is much easier to use that the handheld commander</TD></TR></TABLE>
Plus from my understanding, you can do everything with DataLogit that a Power Excel dealer can do. This might be a bad thing if you don't know what you're doing, like me.
Old Apr 18, 2005 | 08:25 PM
Kengs's Avatar
Default Re: Apexi Power FC (CPR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CPR &raquo;</TD></TR><TR><TD CLASS="quote">
Plus from my understanding, you can do everything with DataLogit that a Power Excel dealer can do. This might be a bad thing if you don't know what you're doing, like me. </TD></TR></TABLE>
I'm not sure if the Datalogit is a hack or an emulator of the Power Excel program, but it sure has a LOT of parameters you can adjust (stuff you cannot access using the Commander alone).
Old Apr 19, 2005 | 12:39 AM
snb18c's Avatar
so how does powerfc compare to hondata??
Old Apr 19, 2005 | 01:34 AM
MiraiZ's Avatar
Default Re: (snb18c)
I have one
Old Apr 19, 2005 | 02:55 AM
Cone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snb18c &raquo;</TD></TR><TR><TD CLASS="quote">so how does powerfc compare to hondata??</TD></TR></TABLE>
leaps and bounds better, unless you want extras like full throttle shift/launch. Which I think is pointless. Where it REALLY matters, the Power FC shines. That is in the maps. The fuel/ignition maps are 20x20, very high resolution. That basically means if there is a spot in your map that needs more fuel or a timing change, you can get closer to that exact spot without sacrificing tuning around that area like you would on a Hondata.
Old Apr 19, 2005 | 05:10 AM
B18CXr's Avatar
most, yes
but not "everything"
Old Apr 19, 2005 | 07:03 AM
Erik95LS's Avatar
Default Re: Apexi Power FC (B18CXr)
I hope to eventually get one of these for my car. Great ECU
Old Apr 19, 2005 | 10:24 AM
AssPenny's Avatar
Default Re: Apexi Power FC (Erik95LS)
Just got mine yesterday Hopefully one of these years I'll get it installed
Old Apr 19, 2005 | 10:38 AM
igyloo's Avatar
Power FC is awesome, adjustments can be made on the fly and you can monitor critical engine parameters from the commander (water temp, knock, air temp, timing, voltage, etc)
Old Apr 19, 2005 | 01:25 PM
rzz's Avatar
rzz
i can't wait to install my powerFC :D
Old Apr 19, 2005 | 05:03 PM
01BB6's Avatar
I know it's not for an itr, but I used the power FC on on my 91 240sx-det and I loved it. Never really had it tuned, and the car felt great regardless. Great product.
Old Apr 19, 2005 | 05:30 PM
Cone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr &raquo;</TD></TR><TR><TD CLASS="quote">you can do everything with DataLogit that a Power Excel dealer can do
most, yes
but not "everything"</TD></TR></TABLE>
I've been meaning to ask you, assuming you've used both, what do you gain by using the Power Excel software?
Old Apr 19, 2005 | 10:04 PM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stealth 95 GS-R &raquo;</TD></TR><TR><TD CLASS="quote">... what do you gain by using the Power Excel software?</TD></TR></TABLE>
One of the significant Excel options might be setting the grids up for boost.
Takashi1978
Dec 2, 2005 09:53 AM
zentraedityper
May 19, 2003 09:20 AM
builthatch
Jan 31, 2003 02:38 AM
R3dL1n3
Apr 23, 2002 09:55 AM
2fcknfst
Jun 28, 2001 07:57 AM
