Car won't start after cleaning the engine bay, help!!!!
Old Apr 18, 2005 | 06:08 PM
silverb18's Avatar
Default Car won't start after cleaning the engine bay, help!!!!
I have cleaned my engine bay like this 5 times before so I don't know what I did wrong but now the car won't start.
It does not even attempt to turn over. I turn the key and all I hear is a faint hissing sound.
When I cleaned the engine bay, I covered the fuse box, intake filter, and dizzy. I checked to make sure there was no water in the plugs, and everything was dry, I also checked to make sure no fuses were blown and they are all fine.
Help....
civiccpedx's Avatar
Default Re: Car won't start after cleaning the engine bay, help!!!! (silverb18)
check to see if you are getting spark and/or fuel. that is weird, only problem i have had with engine cleaning is it puttering.
Old Apr 18, 2005 | 06:10 PM
e jay one's Avatar
learn how to trouble shoot if its not even turning over check the battery and cables and go from there.
Old Apr 18, 2005 | 06:29 PM
silverb18's Avatar
Default Re: Car won't start after cleaning the engine bay, help!!!! (e jay one)
battery seems good, any other thoughts as to what I messed up?
Old Apr 18, 2005 | 06:31 PM
Econo'Box's Avatar
Open up the distibutor and check I covered mine up very well while cleaning mine and it still got enough in there to keep it from starting up. Other than that just start tracing wires starting at the battery.
Old Apr 18, 2005 | 06:32 PM
EVIL Hx Coupe's Avatar
Check connection and grounds at the starter, the check all your fuses and relays in the engine bay.
Old Apr 18, 2005 | 06:46 PM
extra cam needed's Avatar
From: americas finest, calee fourn ya, united states
Default Re: Car won't start after cleaning the engine bay, help!!!! (EVIL Hx Coupe)
did you cover your alternator? I thought that should be covered also.
Old Apr 18, 2005 | 06:49 PM
sickity's Avatar
same thing happened to my friends car when he got the engine all cleaned, just wait until tomorrow and try it and I bet it will fire up, water probably go in somewhere somehow even though it was all covered....
ej7d16y5's Avatar
check ur grounding wires
Old Apr 18, 2005 | 07:10 PM
silverb18's Avatar
Default Re: (ej7d16y5)
i did not cover the alt, it's weird because it does not turn over at all, all fuses are good, I have fuel/spark.
Old Apr 18, 2005 | 07:18 PM
Tdawg1030's Avatar
Default Re: (silverb18)
mabye water got into your battery wires
Old Apr 18, 2005 | 07:31 PM
pitbull325's Avatar
Default If you have fuel and spark......................
If you have fuel and spark then your car would start. Like the other guy said, open up that distributor, let it sit overnight too. Also, take wire dryer (comes in aerosol can like carb cleaner) and spray anything electrical, next time, do this first. Oh yeah, is that you in the picture?.............Good lord!
Old Apr 18, 2005 | 08:05 PM
silverb18's Avatar
Default Re: If you have fuel and spark...................... (pitbull325)
i guess i'll wait overnight, if it does not start, damn I don't know.
Old Apr 18, 2005 | 08:14 PM
AutoXer's Avatar
Default Re: If you have fuel and spark...................... (silverb18)
During the warm months, I usually clean my engine bay about once a month with a high pressure steam cleaner we have at work. I never cover anything, and never had a problem. That is, until I used a Wells dizzy cap instead of OEM that leaked and I misfired like crazy. Replaced with OEM, and never had a problem again.
I'd pull all plug wires, dizzy, fuze box, etc. and check for water or blown fuses. Check for any water anywhere else, spray WD-40 on the critical areas, and if you have a compressor, blow dry wherever you can. Good luck.
Old Apr 18, 2005 | 09:08 PM
silverb18's Avatar
Default Re: If you have fuel and spark...................... (EX_AutoXer)
hopefully in the morning it will, start, thanks for the help, if it does not start, i might have to hit up a shop
Old Apr 18, 2005 | 09:17 PM
y0y0's Avatar
more pics of the girl on your avatar.
Old Apr 18, 2005 | 09:21 PM
khmboostedeh2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej7d16y5 &raquo;</TD></TR><TR><TD CLASS="quote">check ur grounding wires</TD></TR></TABLE>
forgetting a ground wire can lead to the car not starting.
zacatl
Feb 14, 2008 01:49 PM
papyol
Honda Civic (2006 - 2015)
Aug 14, 2007 09:50 AM
etits
Aug 23, 2006 11:37 PM
civic efb16
Aug 8, 2005 09:00 PM
MattTwinTurbo
Dec 25, 2003 11:33 AM
